Question about Maytag Neptune MDE5500AY Electric Dryer
Change rollers on a Maytag Neptune Dryer
How do I access the drum rollers on a Maytag Neptune Dyer ?
Model MDE4000AYW.
  • 3 more comments
  • Anonymous Mar 17, 2014
    removing the front cover to expose the rollers
    i need to change the belt on my Maytag Neptune dryer
  • Anonymous Mar 25, 2014
    wire hook up
    Certain items come out with black streaks
  • Anonymous Mar 31, 2014
    Drum is very noisy during rotation. Most likely worn drum support rollers. Maytag part # PS1330127 is no longer available. Will an other part substitute
    Scholar:
  • 146 Answers
You have to work from the front. Pull the top then the front then you will be able to see everything. Pretty self explanatory.
Posted on Dec 22, 2007
The paddle is not off but loose on Maytag neptune model mde4000ayw dryer, how do you make a repair on it.
you need to remove the drum, and tighten the paddle,, look on this site on how to remove the drum http://repair2000.com/wpoolbelt.htm
May 29, 2011 | Dryers
Maytag performa electric dyer makes dragging noise drum turns but acts like something catches and makes a dragging or scraping sound
assuming nothing is stuck around drum pull off the front and check the fan. If it is noisy for a few seconds after you stop the dryer then the fan may be stripped on motor shaft. while off you can check the front glides and the rear rollers
Nov 17, 2010 | Maytag Neptune MDE4000 Electric Dryer
Where can i get the wiring diagram for the neptune dryer model #mde4000ayw so i can put the 4 prong cord on the back?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Oct 14, 2010 | Maytag Neptune MDE4000 Electric Dryer
I have a Neptune electric dryer model MDE4000ayw. The clothes keep getting stuck around the barrel as the dryer is operating. What is the problem? It also makes a very loud noise as it operates.
You need to disconnect the dryer from power source, open the unit, it sound like the drum has holes on it that stucked your clothes when turning. this problem common to all maytag dryers. The front support glide had chop up . You might likely change the drum or tumbler.
Comment if the solution solve your problem
Dec 06, 2009 | Maytag Dryers
Hi I have a Maytag MDE4000AYW dryer. It is making a squeeking sound off and on when it runs. I took the front off and kinda lifted the drum up and down and it made it without the belt actually turning,...
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
You did the right thing by removing the front of the machine, that is how you check the drum rollers, idler arm with pulley and the motor.
Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 12, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Oct 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Neptune MDE4000Ayw squeaking when running
if its squeaking it means that in wants to be grease or lubed
all mechanical devices need some form of maintence to run properly lube the motor the drum the track wheels but not with wd40 use appliance lubericant or call your local maytag man to come out and do routine maintenance on your neptune
also to the guru if there was a foreign object stuck between drum and body it would be like throwing a monkey wrench into a clock towers gears it would slam to a hault so i dont believe in the object stuck theory
Jun 05, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
1,399 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
