no fuel to injector I have diesel to the injector pump and had it rebuilt when I bleed the pump it will squirt diesel but nothing goes to the injectors.
- Sorry about that I was a little heated about another problem someone had. Did you remove the pump yourself ? If it is a timed pump , there should be a pin off to the side that you push in and turn the tractor over until it locks into place. Not locking it and removing the pump, then reinstalling it,and trying to run it would throw the timing out. Not quite sure how to re-time the injector pump I have never done one. You may have to check with one of the mechanics. Or invite him over for a barbecue and beers . Hope this helps you out.
Aug 19, 2009
- So what you are saying is that you have cracked the line at the injector and there is no fuel coming out of the cracked line?
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
even if out of timing I shoud have fuel pumping to the enjectors ,correct?
" - sagroce
We have just acquired a Rover Ranger ride-on mower. It has the triangular steering bar instead of a...
(More)
We have just acquired a Rover Ranger ride-on mower. It has the triangular steering bar instead of a wheel. It came without an engine though we do have one to put in it .It has SC87 stamped on it but no other identifying marks.It has a few chains etc missing in the engine box and a few unidentified parts from the engine box with it.My question is: is there anywhere that we can get info on bringing it back to life in the with all the right bits in the right places?
I believe i flooded the machine attempting to start it.I cannot find the manual and do not recall...
(More)
I believe i flooded the machine attempting to start it.I cannot find the manual and do not recall which way the choke nob is supposed to be turned
there is two adjustments on each side of the steering box .could some one tell me how to go about...
(More)
there is two adjustments on each side of the steering box .could some one tell me how to go about setting these adjustments .could one side be too tight or not .let me know if you can help ..tractor is a 1953 joublee thanks ed
