Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Red shadows cannot set convergence arows, the red cross will not move to right and line up with white?everything else is fine.
  • bryzellnic Dec 13, 2007
    cannot set convergence arows, the blue cross will not move to right and line up with white? everything else is fine.
Iam having the same issue where i cannot align the RED color ,iam elect savy so if any one can guide me to repair it i would be able to do so
Posted on Dec 12, 2007
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    Red/Orange horizontal lines
    it could be that the tv convergence circuit is going bad. One shure way of finding out is to go to the tv feature menu(picture,audio etc.) and select the customer convergence setting, you should get a cross hair pattern(cross in middle of screen). that cross should be white and by aligning the red or blue colors they should move left, right, up or down
    Jul 27, 2009 | Akai PT5492S 54" Rear Projection...
    Looks 3d
    Do not open anything until you. Go to menu on your remote find convergence and press the volume button to the right go to manual and press right again. you should see a bunch of rectangles, now you should also see a set of red cross heirs press the #2 to move cross heirs up and eight to move down numbers 4 and 6 will move left and right and 5 will place the cross heirs back to the center once you have chosen the selected section to adjust line up the magenta with the other colors using the channel and volume buttons these move the lines up down left to right adjust all lines until they are white. i do not know how to switch from magenta to green or blue but this should get you started on the right track with out having to replace anything. good luck! if you figure out how to switch from maqgent to green or blue please post it so that I may adjust mine as well tahnks
    Dec 26, 2008 | JVC AV-65WP74 Rear Projection Television
    Red double picture with green and blue
    convergence problem there are 2 integrated circuits inside the set needs to be replaced
    Aug 25, 2008 | Toshiba TZ50V51 50" Rear Projection...
    Toshiba 50HX70 Convergence reset
    press mute button once after press and keep pressing mute again and press de menu button on tv .when tou see S on screen press 7 you are in convergence adjusting mode
    Aug 03, 2008 | Televison & Video
    Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
    Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
    May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
    You will need to replace the convergence ICs. You can order them at this link and they provide free support as well as installation instructions with pics so you can do the repairs yourself. You will need to replace both convergence ICs
    http://servicemanuals.vstore.ca/
    Mar 30, 2008 | Toshiba 50H72 50" Rear Projection...
    CONVERGENCE
    http://www.digitalhome.ca/forum/showthread.php?t=21847
    convergence ic bad
    Dec 03, 2007 | RCA P46812BL 46" Rear Projection...
    Red shadow
    bad connections on the converganc ics just solder them this will fix the problem if not replace them
    Nov 03, 2007 | Sony KP-46WT500 46" Rear Projection...
    Toshiba 57h82
    your convergence amp ic's./if you want to cheat/align the other two colors and manualy move the green yoke rings on the green picture tube neck so the green cross aligns with the red and blue.,they shuold form white when all three are aligned,on top of each other.
    Sep 13, 2007 | Toshiba 57H82 57" Rear Projection...
    Panasonic PT-47WX53 47" Rear Projection HDTV Logo
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
