Question about Canon CLC 1180 Copier
Paper getting struck and web blade chanve massage
I am not bale to print any document every paper is getting struck from bypass and tray1 also pls give me suggestion
  • 69 Answers
Hi im jules_09,have you tried cleaning the fed roller on tray2 and by pass tray?try cleanig it with alcohol just get a cloth a soft one then put alcohol on it then rub it on the roller 360 degrees ok,then if does not work your clucth motor id deffective have it replaced
Posted on Dec 02, 2007
Error at display add paper in tary1
Inside the lift motor housing, a gear fits into a molded piece of the housing. The molded piece is broke.
Feb 12, 2014 | Panasonic DP-8016P Copier
I getting Error code 13.02.00 for HP Printer LJ2300dn
solution clean the paper sensor and service the two solenoid that's the problem inside the printer
Jan 21, 2013 | HP LaserJet 2300dn Printer
Tray 1 load recycled letter?
Switch off & on once the printer, load papers in both trays, go to system choose file ask to print, when dialog box appears go to properties, select tray2., the shoot print, check its printing or not. If its printing problem in tray1 paper sensor,clean it.Reason why its not taking from tray 2. In menu settings its selected default tray as tray1. if no paper present in tr1 printer ask to press OK choose another tray to print, during this period indicating error.Best to do: clean all paper path sensor tray1 and tray 2 to prevent further errors... Pl revert..best of luck..
Feb 03, 2012 | HP LaserJet 4100dtn Printer
Blue smudge marks are printing on the edge of the paper
These defects normally occur when printing is attempted on unsupported media or when the printer is set up for a different type of media than the media that is actually loaded into the machine.
Check your media and ensure that it is suitable for use in the printer. Refer to the printer's user manual for information on supported media types and weights. Is the media you are printing on supported in the printer?
Ensure that the paper type is set accurately on the printer operator panel (go to Menu/Paper Menu/Size-Type/Tray1/Type). Is the paper type set correctly on the printer operator panel?
Change the paper weight setting to heavy on the printer operator panel (go to Menu/Paper Menu/Size-Type/Tray1/Type/Heavy Paper/Check button). Try printing your document again. Did the error return? If the error returns, please contact Lexmark Technical Support for further assistance.
Jul 12, 2011 | Lexmark C532n Color Laser Printer
My Brother HL-5240 printer constantly has the paper light on even though there is paper loaded
You probably printed a document that was forced to the manual feed. Place some paper there and it should print. Go to your printer preferences and set the default tray to tray1 instead of Auto.
Jan 31, 2011 | Brother HL-5240 Laser Printer
Tray1 Load LTR
Hope this helps. Please check the printer properties before clicking Ok at print menu command. Now check the available paper tray handler. Try bypass, tray1 or MP tray.
Check also the default paper on Printer Menu command by pressing appropriate setup button. You can try also placing the paper on bypass try if available. The load LTR message means the machine waits a short bond paper on MP tray or on bypass tray.
Jun 16, 2010 | Office Equipment & Supplies
HP laserjet p4014n "Load BOnd paper in tray 1" issue. A couple of weeks ago all the P4014n printers on our network started getting out 0f paper messages on our 2003 servers. The users have to push the...
Check the media settings for your paper trays. Make sure they are set properly, also check the diver media settings. Is the problem happening with a specific print job? If it is check the page setup for that document.
Jan 26, 2010 | HP LaserJet P4014n Printer
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
Ricoh CL3100N
Have you setup for double-sided printing?
Jul 15, 2008 | Ricoh Aficio CL3500N Laser Printer
Tray 1 - load ltr (WHAT DOES THIS MEAN!!!)
Best regards,
Rosener
Feb 08, 2008 | Tally T8006 Laser Printer
Canon CLC 1180 Copier Logo
old marine
old marine
