Question about Frigidaire FEF366 Electric Kitchen Range
Thanksgiving ham still not done cooking
My oven model number is fef336ase. The problem I am having is that when you turn the oven on it starts to heat and then you hear it click like it does when it reaches its desired temp. But it is not heated all the way and it keeps clicking on and off a couple of times a minute. Hopefully this makes sence.
    Scholar:
  • 159 Answers
Hello LeeTB. The problem points to the temp sensor. The part# AP2126609. You can check with a local appliance repair or a hardware store for price and stock. Replacing the part is not too difficult. Unplug or throw the 220v breaker first, locate the sensor in the oven, locate the sensors plug by removing the backpanel, (suggestion- check the wiring & plug of the sensor currently in the oven. You may attempt cleaning & reconnecting before replacing IF the wiring /plug are not brital & frail), replace the sensor, route the wire plug, reconnect the plug, remount the back panel, reconnect the 220v or reset the breaker, and test operation.
Posted on Oct 09, 2008
  • Gene Pitts Oct 26, 2008
    Hello LeeTB, Was the sensor the curprit?
SOURCE:
I have a spril ham that weighs 10.5lbs how long should Idd cook it t in the
it possible is precooked and only needs reheated in an oven for possibly 1 hour at 350 deg
Apr 01, 2018 | Cooking
How do you cook a hickory smoked ham shank portion that is fully cooked already?
I place ham in a large roasting pan or large rectangular pan using a rack under the ham. Set oven to 325 and cook 15-18 minutes per pound. I make a glaze. I glaze half way through cooking time and then a second time 15 minutes prior to removing from oven.
Apr 16, 2017 | Grilling
What temp and how long to cook a 10 lb ham in a turkey frier?
12-17 minutes per pound at 375 is recommended for an oven. I'm not sure of the difference between the frier and oven. Most prepared hams are fully cooked or smoked. Here's a link to check other info on cooking hams.
http://www.bettycrocker.com/how-to/tipslibrary/cooking-tips/how-to-cook-a-ham?utm_source=Email_newsletter&utm_medium=email&utm_campaign=BC_12_23_2016&vcode=AQAAAABFsdYhKGypebKYiGtyMEVUHdxcQGJZky68gCbk2ZRXpAh84Fo6UreMNu2noN699yr-uZMq-s5WshjGdi7heKqVYFWyADXTRxPbFUM4Wf8JXA
Dec 25, 2016 | Grilling
How long do I bake a spiral pre-cooked ham that weight 9.37 pounds? The directions read 10-12 minutes per pound. How long is that is hours and minutes? It's for Easter. Thank you.
A bit late now ,but should have been cooked at approx. 1hour and 30 minutes depending on the heat of the oven, and checking for doneness.
Apr 04, 2015 | Kitchen Appliances - Others
How do I cook pinto beans in a roaster oven?
Soak beans overnight in cold water, drain and rinse, place in roaster (adding a ham bone is a good seasoner), add salt (about 3/4 Tablespoon), cover with water, turn roaster on to 350 degrees, add hot liquid or ham juice when beans are going dry and stir. Don't check too often, because it will release heat and slow cooking time down. Takes 5 hours to fully cook. (Note: bean pkg has quick soak method which works in place of the overnigt soak)
May 07, 2014 | Rival 18 Qt Roaster Oven with Buffet...
How to cook pinto beans in my 22 quart roaster oven
I cook 140 lbs of beans every year at church for a ham & bean dinner. I soak them overnight in 4 large rubbermaid containers (about 35 lbs in each covered all the way to the top with cold water). In the morning I drain the water, rinse beans and divide between about 14 cookers (several of them are the 22 qt roasters). You can put beans in to about 1 1/2 to 2" of the top rim. Put a ham bone in (I pre-cook about 12 10 lb bone-in hams two to a roaster sitting in about 1" water several days before, chop the meat, save the juice and the bones) and a cupped palm full of salt (3/4 to 1 T ?) and cover with water. Cook on about 350 degrees. When they start going dry add the leftover ham drippings that were saved (I usually have it heating in a crockpot nearby so that it doesn't slow the cooking of the beans down).
Aug 10, 2011 | Rival 18 Qt Roaster Oven with Buffet...
Admiral oven not heating to setting
No, I'm sorry, you will have to replace your thermostat to get this oven to heat to proper temperature. We are Admiral factory authorized parts and service professionals and will be happy to get this part out to you asap.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 9 PM CST Monday through Saturday. If you contact us first thing Monday morning, we can next day air this to you so you can have it to cook your Thanksgiving dinner before Thanksgiving.
We look forward to working with you and hope to hear from you soon. Thanks, Ella
Nov 22, 2009 | Kitchen Ranges
Convection oven quit working half way through cooking thanksgiving stuffing
Call us right away with your brand and model number and we'll get the correct part out to you right away in time for Thanksgiving turkey!! We look forward to
working with you.
Oct 18, 2009 | Ovens
How to heat a bone in spiral ham
You could heat it on low power in the microwave at about 50% power for about 10 minutes, let it sit for a few minutes, check the temp around the bone, and do it again for another 2 minutes at a time until it gets to whatever temp you prefer. If you do use the roaster, put a cup of water in the pan, cover the ham, and heat at about 300 for about 30 minutes. If you want a little variety, instead of water you could pour a cup of Coke or pineapple juice over the ham, then cover and heat as noted above.
Apr 11, 2009 | Rival 18 Qt Roaster Oven with Buffet...
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Frigidaire FEF366 Electric Kitchen Range Logo
125 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
