Question about Microsoft Xbox 360 Console
3 red lights
Is there a fix for the dreaded 3 red lights, and does any of those guides out there work or do you have to go out and buy a heat gun and all that crap!!!
A hammer is my solution... a BIG one.
Posted on Dec 01, 2007
  • Berneth Dec 01, 2007
    smash it with a really big hammer
My ps3 switched off. i pressed at the back off and then on. pressed the other button and it went on for about 2 seconds then a yellow light appeared then a constant red flashing light
Hi there, it appears you got the dreaded YLOD(yellow light of death) which means your console has over heated. There is no easy fix for this I'm afraid, if you are anyway technical there are guides out there on how to do this. If not then it's a case of sending it back to Sony. Hope this helps
Jan 19, 2011 | Sony Playstation 3 (PS3) Console
Red flashing lights
Hi, first of all check if you have any warranty as this fault is covered by 3 years warranty from microsoft, so check the date on the back of the xbox, if its less than 3 years old go to their website and enter your details and they will send you out another xbox in place of yours.
if its more than 3 years old or if its been opened before then you have 2 options either pay someone to fix it or fix it yourself.
what 3 red lights are telling you is that you have the dreaded red ring of death, you get this due to the gpu and or the cpu chip over heating, now the most likely causes of this are as follows.
1 the aire ven has been blocked at one end of the xbox stopping cool air being sucked into the xbox, this air vent is the bottom part when you stand it up.
2 after prolonged use the xbox sucks in dust and this blocks the heat sinks and stops the cool air being sucked throught the heat sink and then the gpu chip over heats
3, over time the circuit board can warp causing loss of connection between teh gpu and or cpu chip.
now what has happened is one of the above has caused either the gpu chip and or cpu chip to over heat and this has then caused either bad connection between the gpu and or cpu and the heat sink, so getting the heat sink paste replaced may solve the problem, how ever most cases of rrod is due to the fact the 2 chips have over heated and the cheap lead free solder microsoft uses to bond their chips to the circuit board has failed causing a loss in connection between these chips and the circuit board.
check if you have warranty as this fault is covered
if you have no warranty then you need to either pay someone to reflow the solder or risk having a go yourself and making matters a lot worse, its not easy to do if its the 1st one you have ever done as getting it wrong is very easy, now if as soon as you switch it on you get the 3 red lights this means the chips need reflowing but if you switch it on and the fans run slow but then speed up to top speed then this indicates the the heat sink paste needs teaking off the gpu and cpu chips and also off the heat sinks and new paste putting on.
if you plan on doing this repair yourself use google and search for free rrod repair guide how ever dont ever try the towel trick it will only get it working for few hours then it will be beyond repair, or dont put it in the oven this will destroy most of board, the only way i have found you can do it yourself is by using a heat gun with 2 settings on it and you use the lowest settings, you will be shown this in the guide.
also search for this how to fix rrod using heat gun then hit search follow these instructions carefully getting it wrong will destroy your xbox, just taking it apart is a nightmare on its own so you have been warned, i can send you a repair guide if needed just send me your email address ok
now if your going to fix it yourself use google and type in how to fix rrod on xbox 360 then hit search and have a look at some of the sites, now the chances are the gpu chip will need reflowing now this can be done with a heat gun on its lowest setting, but getting this wrong can do more harm than good.
the best thing to try first is the xclamp fix, go and buy a xbox 360 repair kit off ebay make sure you get the heat sink paste with it, you can get these kits for next to nothing and if you find one with a repair guide then that will make it easier for you, without these parts you wont be able to fix the xbox anyway.
dont do the towel trick it dont work and it causes more harm to the circuit board so dont try that one.
just use google type in how to fix rrod on xbox 360 and look for a guide that shows you how to replace the x clamps with normal machine screws and renew the heat sink paste, its not hard to do and you will get a guide off google with pictures so im sure you can give it a go.
if how ever replacing the clamps dont solve the problem then use google again and type in how to fix rrod with heat gun on xbox 360 then hit search then look through the sites and look for a decent guide that shows you how to do this, dont use a hair dryer like some sites may suggest they just dont get hot enough to reflow the damaged solder under the gpu and cpu chip.
if you do use a heat gun make sure the circuit board is lying flat if its not you will do alot more harm than good so make sure its level.
i cant point you to these sites as its against site police but use google and you will find all you need and you should be able to get it sorted. if its less than 3 years old and you open it up then your warranty will be void and microsoft wont even look at it,
now i repair these for 20 quid plus parts so it comes to about 25 quid, but im in UK and the chances are your somewhere else in the world.
if you are unsure what your doing then please dont try repairing this yourself as you could do a lot more harm than good.
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks,.,,
Dec 13, 2010 | Microsoft Xbox 360 Console
3 red lights -nothing else happening
please rate this solution as i have a whole page of unrated posts, thanks..,..
Dec 12, 2010 | Microsoft Xbox 360 Console
Computer been workin fine. one red light shows up and then all off sudden my screen has loads of dots all over it...?
please rate this solution as i have a whole page of unrated posts, thanks,,,,,
Dec 11, 2010 | Microsoft Xbox 360 Console
Every time I turn my xbox 360 arcade it shows 3 red flashing lights
Dec 08, 2010 | Microsoft Xbox 360 Arcade
I went to turn on the system and it flashed yellow, then beeped twice and the just flashes red. Any ideas what is wrong and can it be repaired??
you can simply fix this yourself look up on youtube what happened is that 2 chips on the ps3 have disconnected from the mother board and you have to use a heat gun to reheat the chips or send it in to sony for like 150 bucks   look up on youtube for a fix type in yellow light of death fix
Aug 22, 2010 | Sony Playstation 3 (PS3) Console
When I switch my PS3 on, it just switches itself off to 'stand by'. I did have another problem with the PS3 in the summer 2009 when my driver went and sent it to Sony to fix it. I had this problem since...
if there is a flash of a yellowish light and then followed by a blinkin red light read on:
You have the dreadful blinking red light of death. Long story short the system is broken due to overheating and heat damage to the motherboard and you have a few options:
  1. (do what you have already done and) send the system to sony and receive a refurbished system for $150.
  2. find a local to do it for much cheaper
  3. watch vids on the web (youtube.com) and fix it yourself but it is fairly difficult.
  4. buy a new ps3.
I hope I have helped and please feel free to ask me any questions and let me know how it goes.
Jan 03, 2010 | Sony Playstation 3 (PS3) Console
I have three flashing red lights
You have the dreaded red rings of death the only way to fix it is to send it back to micsoft it will be free if you havent had it for less than 3yrs if not you will have to pay 120dollars.
Oct 27, 2009 | Microsoft Xbox 360 Console
Do Not Use A Heat Gun On Your Xbox 360! Send It In To Microsoft! Find Out Why Here!
If you are looking for an Xbox 360 3 Red Lights Fix do not use any guide that suggest a heat gun fix!
Although a heat gun is used sometimes you are better sending it in to Microsoft to do the work!
If you buy any guide with the heat gun fix ask for a full refund you will need it!
If you still want to fix it yourself then click the link below and get a FREE preview of an easy 30 minute fix that does not use a heat gun:
Xbox 360 Repair
Mar 15, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
14 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
