I installed the stereo, and everything works well. except for when you turn the volume up the stereo will turn itself off then back on again.. some times when volume is at about 15 and higher. i checked for loose connections and i am not running a amp with this setup please help me figure this out...............
What kind of car do you have the stereo in? It sound exactly like a bad ground wire. To trouble shoot this, simply find a good clean ground point to hook the black wire from the radio to. you can usualy find somewhere behind the dash that the factory has grounded things to. I asked what kind of car, because some fords, and nissans do not have a ground wire in the factory radio harness, even though the adtor harness you may have used will have one. Hope this helps.
Your pushing too much wattage
