Samsung LN-T3253H 32 in. LCD Television
Problem for Samsung LN-T3253H 32 in. LCD Television
Lcd screen has a visual whole ... can it be repaired>
By ronmoore729 on Aug 17, 2009
our son 'shot' the screen with a rubber pellet ... left a white whole in the picture, and a black vertical line beneath the 'whole'. there is no physical damage to screen, only visual. can this be repaired?
Solution #1
posted on Aug 17, 2009
Not Rated)
vinhson65
Rank: Guru  Samsung Expert
Rating: 87%, 57 votes
LCD is fragile screen, you screen may be damage even when your finger point in. If you still have warranty, claim for the replacement. Otherwise, if you are in OOW, it is costly if you want to replace the new one. So, you have bad luck then.
Was this helpful?
Yes
No
Popular Solutions for Samsung LN-T3253H 32 in. LCD
Questions and Unsolved Problems for Samsung LN-T3253H 32 in. LCD
Do you recommend Samsung LN-T3253H 32 in. LCD Television?
Answer
Answer
After trying to turn the channel yesterday on my Samsung LCD HDTV (32"), a black box in the top... (More)
Answer
TV went out while watching DVD. It will not turn on now. Red "on" light goes on and off
Answer
Has an annoying high pitched ring in the background
Answer
Using digital cable. Screen went black, but can still hear sound. Checked all connections, reset... (More)
Answer
I have a samsung LNT4665fx. It turns on just fine, and the screen looks normal. After about 15... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung LN-T3253H 32 in. LCD...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 753
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
