Question about Kenwood DNX7100 Car Video Player
E brake override
How do i bypass the dvd so that i can whatch movie while driving
  • Anonymous Feb 22, 2008
    HOW DO I OVERRIDE PARKING BRAKE ON PIONEER AVH-P4900DVD
  • Anonymous Mar 16, 2008
    OVER RIDE PARKING BRAKE WIRE FOR PIONEER AVH-P4900DVD
    Problem Solver:
  • 9 Answers
Ground the parking brake wire to any metal surface that is handy. Just as solution 2 suggests. I accidently clicked the top "Guest" as the best solution when Solution #2 was the one I meant to click on. Ground it and enjoy!
Posted on Mar 14, 2008
Just ground the brake wire...also, you can put a toggle switch in between the HU and ground, so if you get pulled over by police, flip the switch, and they'll never know.......
Posted on Sep 11, 2009
Ground parking wire to pink/ gray parkk/sens wire
Posted on Mar 30, 2008
I just did that yesterday. Just ground the wire which is supposed to be connected to parking sensor. This will bring back full bluetooth and dvd capability for the unit - Have fun
Posted on Dec 02, 2007
Jump the cables outta the back of the unit
any pro can do it
Posted on Dec 01, 2007
Its easy all you have to do is switch the wiring around, put the red and the yellow wire on ground and the ground wire for the deck to the red battery wire, good luck :)
Posted on Aug 27, 2009
2 Suggested Answers
SOURCE:
SOURCE: ebrake override
Take the E-brake wire coming from the stereo and ground it to any metal part on the car by securing it under a screw.
Posted on May 13, 2008
How to bypass the parking brake switch for an 06 jensen VM9411
Here is the solution
1/ insert the dvd movie
2/After the disc loads and plays you will seea blue screen telling you "it is unlawful to drive with a movie bla bla bla"
3/Activate the brake sequence and disable the blue screen using the hand brake,the switch method or anything else to give the unit its 3 pulses to disable that freakin blue scrreen.
4/Next,on the main remote press stop twice,then 1,2,6,4.
5/You will now see a hidden menu that says.
Region Code
Brake Override(I know you are droling by now)
Macrovision(Watch all the burned and pirates you want if this option is off)
Loader Version
Model Version
6/Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle
on ,off or witch region code you want.
7/This is what you want.
Region code 1
Brake override ON
Macrovision OFF
When your done,click SYS SETUP on the remote TWICE to save the settings and vingo.
Mar 09, 2009 | Jensen VM9510 Car DVD Player
Pyle override park brake code
You can run the brown wire to a ground and that should work for you. Would you happen to know the importance of the pink wire?
Dec 30, 2008 | Pyle PLTS76U Car DVD Player
BackGorund Change on a Jensen VM9311TS In-Dash DVD player
There is no e-brake override code. You have to hardwire it to bypass the e-brake. Take the peach-colored wire and ground it to metal inside the dash. Put a toggle switch inline on the wire and mount it somewhere you can reach it. When you get the blue screen when starting a movie, open the switch for 3-5 seconds, then close it again to reapply the ground. Your movie will start up, and you can then drive away with it playing.
Sep 24, 2008 | Car Audio & Video
Overriding e brake video defeat
Aug 24, 2008 | Jensen VM9510 Car DVD Player
Vm 9512
yes ther is a bypass code!!!:))
u have to go on the tools menu,select the language than take the remote controle and type 543210
u will see the secret menu when u can override e-brake :))
May 25, 2008 | Car Audio & Video
My head unit wont play dvd's wile im driving
Apr 16, 2008 | Jensen VM9020TS Car DVD Player
Whats the code sequence?
All you have to do to bypass your brake is insert a DVD into the dvd player. When the blue screen pops up just take your remote and press stop stop 1,2,6,4 that will bring up a manufacturer menu that you wont be able to see. Once you do that use your right joystic and press down then right that will turn the brake override on and also make the brake wire completley useless. then you want to set the region code to 1 and turn the macrovision to off. Once you do that all you have to do is press SYS SETUP on your remote control twice to save the settings. Thats it you are all set you will never have to worry about the brake again and you can watch the movie while driving but be careful if you drive eratic and get pulled over with a movie playing its a big fine. Enjoy!
Mar 10, 2008 | Jensen VM9510 Car DVD Player
Bypass the parking brake for vm9412 jensen
Hit Setup On Remote.
Select Language.
Get Remote And Hit 5,4,3,2,1,0.
Listen For Beeps. Touch “Hammer/Screwdriver” Logo.
Select Brake Override
Switch To Brake Override “ON”
Now Hit Setup On Remote.
this works thank you for posting this.
derek
Dec 25, 2007 | Jensen VM9510 Car DVD Player
Ebrake override
Dec 01, 2007 | Kenwood DNX7100 Car Video Player
Bypass brake for a jensen vm9311
the wire is pink and say parking on the wire.
Nov 24, 2007 | Panasonic CQ-C3300U CD Player
Kenwood DNX7100 Car Video Player Logo
900 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
