Computer restore
Finding my restore disk damaged I used a disk from another computer. It re-partitioned my HD. After not activating Windowds XP I cannot do anything.
Is it possible to download adequate files to boot up and then reload windows XP.?
  • 97 Answers
To avoid problems again like this activate it first, if your not familiar to some techniques it very hard for you to understand what I am gonna tell. The most short term for this is to back up all your files[slave your hard disk to another computer if desktop, if not try to make some ways] and then reformat your computer./ Thats it!
^_^
Posted on Feb 07, 2008
Is this computer able to dual boot win 7 and xp
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
b>
Jan 06, 2013 | HEWLETT-PACKARD Pavilion Desktop with AMD...
Tip
How to fix "Operating System Not Found" error when you start your Windows...
When you try to start a Windows XP-Based computer, you may receive an error message that the operating system is not found.
APPLIES TO
Microsoft Windows XP Home Edition
Microsoft Windows XP Professional
Symptoms
When you start a Windows XP-Based computer, you may receive one of the following error messages.
Error message 1
Operating system not found.
Error message 2
Missing Operating System
When you start your computer to the Recovery Console to recover functionality, you may receive an error message that resembles the following error message:
Setup did not find any hard drives installed on your computer.
CausesThis issue may occur if one or more of the following conditions are true:
The basic input/output system (BIOS) does not detect the hard disk.
The hard disk is damaged.
Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
Note Some third-party programs or disk corruption can damage an MBR.
An incompatible partition is marked as Active.
A partition that contains the MBR is no longer active.
Resolution To resolve this issue, use one of the following methods, depending on your situation.
Contact your hardware manufacturer
Your best bet may be to contact the manufacturer of your computer or your hard disk. The manufacturer may have a utility that you can use to perform a more detailed scan for damaged areas of the disk and help verify the correct BIOS settings. However, be aware that the damage to your hard disk may be serious. Sometimes this means that your only solution is to replace your hard disk.
If a fix or workaround is not available, you can use the "Advanced Troubleshooting" section to try to resolve this issue.
Advanced troubleshooting
This section is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact support. For information about how to contact Microsoft support, visit the following Microsoft Web site:
http://support.microsoft.com/contactus/
Method 1: Verify the BIOS settings
Verify the computer's BIOS settings to make sure that BIOS lists and recognizes the hard disk. See the computer documentation or contact the hardware manufacturer for information about how to verify the BIOS settings.
After you verify that the computer's BIOS detects the hard disk, restart the computer, and then test to determine whether the issue is resolved. If the issue is not resolved, or if the computer's BIOS cannot detect the hard disk, you may have issues with your hardware. Contact the hardware manufacturer to inquire about how to resolve this issue. You may have to replace the hard disk.
For information about how to contact hardware manufacturers, click the appropriate article number in the following list to view the article in the Microsoft Knowledge Base:
65416 Hardware and software vendor contact information, A-K
60781 Hardware and software vendor contact information, L-P
60782
Hardware and software vendor contact information, Q-Z
Method 2: Use Recovery Console
Use the fixmbr command in the Windows XP Recovery Console to repair the MBR of the startup partition.
Warning This command can damage your partition table if a virus is present or if a hardware problem exists. If you use this command, you may create inaccessible partitions. We recommend that you run antivirus software before you use this command. We also recommend that you backup your data before you use this command. If the fixmbr command detects an invalid or non-standard partition table signature, the fixmbr command prompts you for permission before rewriting the MBR. The fixmbr command is supported only on x86-based computers.
For more information about Recovery Console, click the following article numbers to view the articles in the Microsoft Knowledge Base:
314058 Description of the Windows XP Recovery Console 307654 How to install and use the Recovery Console in Windows XP
on Jul 15, 2010 | Computers & Internet
Reset dell mini10
restart press key F11 HOLD THE KEY TILL RESTORE STARTS
RESTORE TO FACTORY SETTINGS OR GERT AND EXTERNAL CD/RW USE THE FACTORY CDS
Many years ago, Dell started shipping computers with a small Dell Utility partition hidden at the front of the hard disk, followed by the main (Windows operating system) partition. Beginning around July 2004, select Dell computers in the Dimension and Inspiron model lines began shipping with a third partition hidden at the end of the hard disk. This third partition contains the "Dell PC Restore by Symantec" utility--colloquially referred to as DSR ("Dell System Restore"). This is a utility that can be used to return a computer to its "as shipped" state, with the XP operating system restored to the condition it was in when the user first unpacked the computer from the box. Pressing the right keys when the computer is starting up will boot this DSR partition.
Jul 25, 2012 | Computers & Internet
How to install operating system
If you do not have the restore disks or a restore partition, you need to take this PC to a IT Professional to have it loaded for you. This will entail the Operating System, Updates, Drivers, and 3rd party antivirus and anti-spyware.
Aug 26, 2011 | Toshiba Satellite P105-S6197 Laptop
I'm unsure if i need a restore cd to restore my notebook back to factory settings can someone please help me
Welcome to Fixya
You dont need to use the recovery disk. The machine has a built in recovery partition. Unless you re-partion the HD. Re-partitioning the HD will destroy the restore partiotion. Here's the procedure for the restore factory state:
Restart your computer and press F9 key when the computer is starting up. On some computer you can press the F4 key and you will be able to activate the partition that is set inactive. After that your computer will restart and you can restore the system as you like. Have a good one!
Mar 29, 2011 | ASUS K40 Notebook
My hp beeps and shows a black screen when trying to start up
Hp Support ---->Link.
or :
Cause 1 This issue may occur if you have a CD, a DVD or a floppy disk in your CD, DVD, or floppy drive when you start the computer. Cause 2 This issue occurs if one or more of the following elements are corrupted and will not load during the boot sequence of the computer:
  • Master boot record
  • Partition tables
  • Boot sector
  • NTLDR file
Method 1: Troubleshoot the specific element that causes Windows not to loadNote This option requires that you perform multiple steps to determine the exact element that causes the issue. This option may allow for you to keep customizations in Windows.
  1. Restart your computer in safe mode. To do this, press the F8 key while Windows is starting. Then, create a Windows XP boot disk to start the computer.
    For more information about how to create a Windows XP boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 305595 (http://support.microsoft.com/kb/305595/ ) How to create a bootable floppy disk for an NTFS or FAT partition in Windows XP 315222 (http://support.microsoft.com/kb/315222/ ) A description of the Safe Mode Boot options in Windows XP If you can start the computer from the boot disk without receiving an error message, the damage is limited to the master boot record, the boot sector, or the NTLDR file. After Windows XP is running, immediately back up all data before you try to fix the boot sector.
    Use Disk Management to view the partition information and to verify that the disk partition (or partitions) is correct. To use Disk Management, follow these steps:
    1. Click Start, right-click My Computer, and then click Manage.
    2. Expand Storage, and then click Disk Management.
    If invalid partitions are present or you cannot start your computer by using a boot disk, consider reinstalling Windows XP on your computer and restoring your data and configuration information from a recent backup.
    If you do not have a current backup copy of the data on the computer, contact a computer specialist to determine the best method of data recovery and configuration.
  2. Run a current virus scanning program to verify that no virus is present.
  3. Repair the master boot record by using the FIXMBR command from the Windows XP Recovery Console.
Oct 06, 2010 | HP Computers & Internet
My Thinkpad/Lenova R51 had a hard drive failure. I got a new hard drive and installed it in the computer. Then I attempted to use the rescue and recovery cd and the product recovery cd's that came with...
The partition that had the Lenovo image was on the old hard drive not the new one you purchased, so you will not be able to restore from image. Look on the bottom of the laptop for the Windows version. Is it Windows XP Home or Windows XP Pro? You will need a Microsoft Windows disk to reinstall and you can use the serial number on the sticker to activate. This is all legal because the serial number belongs to the laptop. Unfortunately, finding a Windows software might be difficult. Ask a friend if they have a disk of the same operating system.
Might be easier to take to a tech and pay $60.00 (I wouldn't pay nmore than that) and have them reinstall basic windows and drivers for you.
Sep 16, 2009 | IBM ThinkPad R51 Notebook
Replacing with harddrive 40GB
Did you simply swap hard drives? "Couldn't find NTLDR" basically means the PC cannot find any version of Windows installed because the boot file is missing. This could be because you have a CD in the drive or the hard drive is missing or broken.
If you put in a new hard drive to replace your older smaller one you need to reinstall Windows on that new 40GB drive or it just won't work. If you have some PC Tech friends they should be able to move the data which is tricky or help you out.
Mar 18, 2009 | Compaq Presario 5000 PC Desktop
No boot sector on hard drive
FIXBOOT writes the "boot sector" to the specified partition.
FIXMBR repairs or replaces the master boot record of the disk.
You will also want to ensure that your partition is active, because Ghost will not make a partition active unless you do a sector-by-sector backup and complete restore.
Here's what to do...
Boot from the XP / 2000 CDROM and allow the setup to begin. Once the beginning files are copied, you will be asked to Install Windows or use the Recovery Console. Please choose "r" here, to run the recovery console.
You will now type in the following commands when the prompt appears:
chkdsk /f
* This will repair any obvious file system damage, which could complicate things.
diskpart
* This will run the XP disk partition utility. We will be checking to see if your partition looks OK. If you see your partition, and the information diskpart provides appears correct, then that's a good thing. :)
Press [ESC] to exit Diskpart, when everything looks peachy.
fixboot
* We'll write a new boot sector, so the computer knows how to boot the computer
fixmbr
* We'll write a new boot record, so the computer knows how to boot Windows
You should be taken care of. If it still does not work, you may need to delete your partition(s) using diskpart, then recreate the partition(s) (using diskpart, again).
Feb 22, 2009 | Dell Inspiron 3800 Celeron 500MHZ...
I am replacing the hard drive in my Dell Dimension L866r
Do you have a floppy drive in the drive if so remove it. Also turn off your floppy drive or just remove it completely it could be bad sending false info to the main board saying there is floppy drive in the computer. Also try and turn the drive off in the BIOS
Jan 16, 2009 | Dell DIMENSION P3/866MHZ 128MB 20GB DVD...
Computers & Internet Logo
290 people viewed this question
Alun Cox
David Payne
David Payne
