Frigidaire Thru-Wall/Window Air Conditioner
Problem for Frigidaire (FAC124) Thru-Wall/Window Air Conditioner
Window unit not cooling how to put in freon
By bbkerley on Aug 17, 2009
window unit not cooling, how to put in freon
Solution #1
posted on Aug 17, 2009
Not Rated)
vi_llur_ca
Rank: Guru
Rating: 92%, 143 votes
You have to put a piercing valve on the sucction side because this units don't come with service port, but if you going to add freon ,it is better to fix the leak before and after that replace the drier and vacum the system.
Was this helpful?
Yes
No
Popular Solutions for Frigidaire Thru-Wall/Window
Questions and Unsolved Problems for Frigidaire Thru-Wall/Window
Do you recommend Frigidaire (FAC124) Thru-Wall/Window Air Conditioner?
Answer
Answer
I am currently installing my new zw5000 ac. I have followed the instructions and everything is ready... (More)
Answer
I have a window A/C unit. It has worked for years. It worked last month, but it wont turn on now.... (More)
Answer
I have a frigidaire FAA074S7A 6500 BTU window unit from Lowe's. Can window units be mounted in a... (More)
Answer
I have a FRG Model#FAS256R2A only one year old . When it runds it shoots drops of water out of the... (More)
Answer
I got this unit from Amazon. I sent a check for an extended warranty a couple of weeks ago in the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire Thru-Wall/Window...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
