Question about Carrier 38BRC036 Air Conditioner
Propane insert fireplace
We have an insert propane fireplace,it was moved in the spring and reconnected(but not by the same people) in the fall. It had an on/off switch on the wall before the move,now it doesn't so we can't turnit on. The pilot is on, but because of the switch location, we can not turn it on. The model is a d33nr/cdv33np, continental, the company that sold it to us nolonger servics our area so won't help us.
    Guru:
  • 462 Answers
Ask your new propane dealer to recommend some one. I don't know about it but is the electric for a fan? Or for the gas to flow and turn on the heat? An extension cord for now will get you going (bet you've already done that.
Posted on Mar 28, 2009
  • 86 Answers
No idea
Posted on Mar 17, 2008
Lights but turns off in about a minute
It might have a built in thermostat that will light the heater when room temp falls below a certain temp. It should then relight and warm things back up. As long as the pilot stays lit it should work just fine.
Feb 08, 2014 | Emberglow Melbourne Oak 24 in. Vent-Free...
Majestic DVR 36 RN gas fireplace pilot flickers when ignited, eventually gets to full pilot. Ocasionaly burner shuts off, pilot remains on. Also, need owners manual for part numbers. Help.
Does your fireplace have a thermostat connected? If so, that may be why the pilot stays on and the burner goes off. Otherwise, it could be a bad thermopile. If that is the case, I recommend you just replace the entire pilot assembly. It is an older model and manuals can be hard ti find. If you still have trouble, I recommend you contact a local certified gas appliance technician.
Jan 12, 2014 | Majestic Fireplaces Majestic Topaz 20ILDV...
Need blower for model #crhfd400rt-m-m gas fireplace
PDF]BLOWER ACCESSORY - Home Depot
www.homedepot.com/.../0e104dad-8f0d-4383-aa50-11...
The Home Depotinstructions may result in a possible electric shock, fire hazard and will void ... Thisblower contains assembly instructions for the following models and item ....CRHFD400RT-M-M (Item # 0328248), BD23 series, Q stove, PCSD25RT .... andrequire no further lubrication. ... Type of gas used (Propane/LP or Natural gas/NG).
Lowe's STYLE SELECTIONS Blower Fan for Gas Fireplace ...
answers.lowes.com/answers/0534/product/3162223/questions.htm?...
... real customers have contributed for the Blower Fan for Gas Fireplace Inserts. ... Cedar Ridge 32,000 BTU Vent-Free fireplace (Model# CRHFD400RT-M-M)?
Cedar Ridge Hearth Crhqd250t - Sepeda Ontel Klasik Vector
efratoium.xyz/cedar-ridge-hearth-crhqd250t/
Feb 26, 2013 | Heating & Cooling
My fire place elecric starter won't work after running out of propane
Most likely, you need to "bleed the line". The new propane needs to travel to your fireplace, but you have a huge air pocket in there now since it ran dry. It takes forever for the air to "bleed" out through the tiny orifice of a pilot light, especially if the distance from the fireplace to the tank is far.
Jan 28, 2013 | Skytech 3301 Thermostatic Gas Fireplace &...
How do I convert my fireplace from natural gas to propane
Buy a kit from nat gas to propane in saying that some fireplaces come with both kits .
change injector in pilot and the injector in main burner and the spring in the reg on the fire place , This info should come with the converstion kit
Apr 17, 2012 | Heating & Cooling
Where can i get a replacement motor for my electric fireplace insert model fl18-r I live in smith falls ontario
you can try grainger.com and go to industrial motors with the model no.,h.p rating manufactures name and voltage. They carry a large selection and are good about service. Hope this helps you. Thanks
Jan 03, 2011 | Leisure HOMEPRIDE Electric Fireplace...
I have an Enviro propane fireplace insert installed last year & it worked fine. The tank & regulator were changed because I got another gas supplier. For some reason now I have a low flame....
It sounds to me like you need to increse gas pressure. Most propane fired units need at least a 11 inch water column of pressure for proper operation. This relates closely 7.5 ounces. I would have regulator checked out by qualified service techs. Thank you
Nov 20, 2010 | Mr. Heater Mr Heater Portable Buddy...
Light soot around propane fireplace vent
burners burning yellow , in complete combustion , blocked air ways to burner , it needs a service soon as poss
Dec 22, 2008 | Empire DV-215 Direct Vent Natural Gas...
Propane fireplace insert won't light
Gas apliances have safety features built into them so you don't blow yourself up. The pilot heats a thermocoupler which tells the gas valve there is a flame, open the main gas to the burner. If you can see the flame area of the pilot look for a round post about 3/16 inch in diamiter. This should be directly in the flame, if not bend the bracket so it is in one side of the pilot flame. The thermocouple is attached to a mounting bracket. This will be held in place by a 1/4 inch hex screw. remove the screw and the capilary tube leading to the gas control valve. Before you do anything, close the main gas supply to the fireplace and disconnect the power to the fan. You may need to semi dismantle the fireplace to get the thermocouple. The gas valve end is a brass 1/4 pipe thread plug. Turn the outer nut and remove without twisting the tube. Reverse this order to install a new one. Besure not to twist the capilary tube, tighten brass nut 1/4 turn past hand tight. Your better heating supply house will have these in stock. Restarting the pilot will take a few tries because the gas was off. Your gas suplier would charge about $75 to fix this. if you don't have the proper tools and it dosen't look pretty stright forward don't do it. You could get dead.
Dec 01, 2008 | Heating & Cooling
Carrier 38BRC036 Air Conditioner Logo
255 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
