GE Profile? PCF25PGW Side by Side Refrigerator With Ice Box
Problem for GE Profile? PCF25PGW Side by Side Refrigerator With Ice...
Water leak under GE Profile refridgerator when using door water
By thespice89 on Aug 17, 2009
When I use the water dispenser in the door of my GE Profile side by side refrigerator the water pressure is so low it takes a long time (1min or so) to fill a 16oz cup. More importantly there is a lot of water that comes out of the bottom right of refrigerator onto the floor. I pulled the unit forward and checked the water line in the back but I didn't see any leaks. How can I fix this?
Solution #1
posted on Aug 17, 2009
Not Rated)
Sea Breeze
Rank: Guru  GE Refrigerators  Expert
Rating: 90%, 745 votes
The water dispenser problem may be due to a defective water control valve. But when the refrigerator leaks this needs to be solved. I have a lot of different ways and reasons listed so click on the below link and read over this and use the part that applies to your refrigerators leaking problem. You also can contact me here or by email should I not get any messages here from you. Hope this helps and we will work on the dispenser problem next, Thanks, Sea Breeze
appliancepartsse@yahoo.com
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Comments:
Aug 17, 2009
- As the water control valve sounds to me that something is restricting the flow through either the water control valve or a flow meter which I hope is not the problem. The water control valve has 3 solenoids and we need someone to unplug the wires and measure the resistance in each coil. It is possible the coil for the dispenser is defective. When checking with an OHM meter all 3 should show the same or close to the same amount of resistance. Here is a photo of the valve. We also should check the flow of water before getting to the valve and after leaving the valve. Sea Breeze
Was this helpful?
Yes
No
Popular Solutions for GE Profile? PCF25PGW Side by
Questions and Unsolved Problems for GE Profile? PCF25PGW Side by
Do you recommend GE Profile? PCF25PGW Side by Side Refrigerator With Ice Box?
Answer
Answer
Water is leaking in the front of refrigerator only when the water valve in the supply line is turned... (More)
Answer
icemaker in side by side 25 cu ft quit working water is not dispensing into system
Answer
water on floor. Fridge is leaking- checked freezer drain and its fine-how do i find evaperator lines
Answer
when you press the valve the water comes out in a full stream for about 3 seconds and then goes to a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repairmen
in , AR
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
