Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Fridge is cold but freezer will not stay cold
The freezer on my GE Refrigerator with freezer on the bottom won't stay cold. The fridge works OK but the freezer gets up to 21 or 22 degrees. Even if its left closed for a few days it won't get down below about 4 or 5 degrees and the first time its opened it goes right back up. The fan seem to blow OK and its clear of dust and lint behind and underneath.
SOURCE:
mikedurland
  • 481 Answers
SOURCE: THE FRIGDE IS TOO WARM.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 29, 2008
22yooper
  • 828 Answers
SOURCE: Refrigerator warm, freezer cold
Totally Unreasonable if you don't mind me saying so. The person who told you that story was thinking of an absorption unit more than likely.
Your proble is related to the defrost system of your refrigerator. There is a timer that automatically starts the defrost. It energizes the heaters that defrost the cooling coil. After the coil reaches a preset temperature a defrost terminator turns the heater off for the remaining time on the timer cycle. You could have a bad timer (stalled) which would not start the defrost. Locate the timer and turn the clutch head screw clockwise very SLOWLY until you hear one audible click. The defrost should take place and will be indicated by water in the drain pan under the refrigerator. If after 25 minutes it does not restart in the cooling mode turn the screw once again to the second click and replace the timer.
If the refrigerator restarts after 18-22 minutes and defrost does not take place your problem is in the heater circuit. Open heater or thermostat (termination switch)
Posted on Jul 16, 2008
SOURCE: Freezer is staying cold (below 0), but Fridge won't cool
Failure to stay cold
Posted on Jul 23, 2008
  • 4 Answers
SOURCE: Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech.
Posted on Aug 15, 2008
SOURCE: Kitchenaid KSRA22ILSS02 fridge won't get below 41 degrees
Try shut down for overnight and turn back on next day. I had same problem - cooling air duct was blocked by ice
Posted on Nov 09, 2008
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
I have a GE Profile PDS22MCR bottom freezer. The freezer is getting colder and the fridge is getting warmer....... What could this be?
your damper assy isn't opening to allow cold air from the freezer up into the refrigerator,its located on the rear wall in the refrigerator compartment,you need to make sure theres a fan running in the freezer,then if so you should feel cold air blowing up in the refrigerator compartment,remove this panel and see if its shut,if no air is felt then the damper door is either broken or jammed shut or if its o.k.,then your control board in the rear of the unit could be defective not letting power to the damper door or even on of your thermistors in the side walls of the refrigerator that monitor temps in the refrigerator and freezer could be defective
Sep 28, 2012 | GE PDS22MCR Bottom Freezer Refrigerator
I have a PFSS5PJXCSS French door with bottom freezer GE Profile refrigerator. Was making an awful noise and both fridge and freezer were warm. I opened back panel of freezer to find ice everywhere,...
Had similar problem, freezer was working fine, but fridge was warm, (68 degrees) It wasnt my damper, the mother board was fried, and so was the inverter board that told the compressor what to do, after having the inverter and two mother boards replaced.......I threw it out, biggest piece of ****, only three years old, and Sears would not stand behind it, even though I used their repairmen. I will never buy another GE product, or enter a Sears store again
Jun 03, 2011 | GE Profile PDS20SFS Bottom Freezer...
Freezer works but fridge doesn't stay cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
GE Profile Freezer not cold enough
VACUMM THE COILS UNDERNEATH THE THE FRIDGE THEY MAY BE CLOGGED WITH LENT AND DUST...... HOPE THIS HELPS
Jun 10, 2009 | GE Profile Stainless Bottom-Freezer...
Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
Oct 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
75 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
