Question about Zanussi WJS1265W Front Load Washer/Dryer
Zanussi FJ1254 W - Machine does not fill
Hi
When i turn the machine on and then press the start button, for a few seconds one of the lights comes on (the WASH LIGHT, which has double bars) and then the start/pause button starts flashing alongside two other lights (single bar light which is the prewash light and the empty basin light wihch is the RINSE HOLD light).
Ive checked my manual and it says that if the START/PAUSE light alongside the RINSE HOLD light flashes then it means that water is not getting into the machine. Ive checked the inlet hose and water is flowing through it fine, but that water doesnt seem to be getting into the machine..
any ideas??????
Thanks
  • 139 Answers
Yes if you remove your soap draw and take a look inside you will see that there is all residue built on the top part of the internal draw, Either you can jet wash it off or replace the soap draw,,
this should solve your problem.. if that does not work then one of your solinoid valves at the back is faulty...
Posted on Dec 02, 2007
SOURCE:
Zanussi 1116
I would call an appliance tech. This definately is an advanced issue required by a tech to diagnose.
May 06, 2012 | Washing Machines
My Zanussi Electrolux Essential 1200 washing machine ZWF12070W1
Most times unplugging a washer for 5 min or so will reset to factory. Some units just a quick unplug works too. But I'm not totally familiar with yours.
If it's going to be hard to unplug just turn off the breaker to it.
Hope this helps
Feb 27, 2018 | Zanussi ZWF12070 Front Load Washer
ZANUSSI FLE1015W,THE problem i have is that once i turn on the machine and press fabric button the program lights come on and the start/pause button light flashes i press the start/pause button a sound is...
Have you selected a program?
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 22, 2011 | Zanussi FLE1416W Front Load Washer
Zanussi ZWF580- after the wash cycle I press the red button to rinse & spin but it just tumbles & rinses again, then the red button comes on again. This could go on all day. I find that to finish...
If the START / PAUSE button lights up red, the washing machine detects a malfunction. Now you should count how many times the START / PAUSE button lights up red and tell to us what kind of malfunction is being done.
Try to rapid reading of alarm codes when the appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and the nearest option button for at least two seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
LED indicator START / PAUSE with red light = indicates the first digit of the alarm code (family)
• LED indicator START / PAUSE with green light = indicates the second digit of the alarm code (internal number of the family)
Dado
Jan 21, 2018 | Zanussi FS1155W Front Load Washer
Hi! I have a Zanussi IZ12 washing machine. After I turn it on, the door will not open and start/pause button just flashes. (I can select program and press start/pause, it just beeps, but the machine do...
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
Jul 14, 2010 | Zanussi IZ12 Front Load Washer
We have a Fisher and Paykel toploader, smart drive 603. After setting up a washing cycle and pushing the start button, the machine starts for a few seconds with the water filling in in short bursts (rather...
Hi just read you posting.Could you please confirm the fault code for me.1st push and hold the WASH TEMPERATURE DOWN button then press the POWER button until the machine gives you 2 short beeps,then release both buttons.Now press the SPIN UP or DOWN button until the HOLD and SLOW SPIN LEDs are both on.Now the fault code will appear in the WASH PROGRESS lights.Please reply to confirm which lights are lit.Are they the same as your 1st posting?To get back to normal operation turn machine off at the power point.Looking forward to your reply.
Jul 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
Zanussi aquacycle 1000 start pause button
Try some WD40 on the door lock on machine (not on the door) & open and close a few times. Of course the mains plug should be off the wall socket.
Feb 28, 2009 | Zanussi IZ12 Front Load Washer
Zanussi ZWF 1631W
Try to pull out the power-cable from the contact. Wait for at least 30 seconds then reconect it again.
Sometimes that can help but not always. If that dosent help you need to let a profesional repairshop fix your machine.
Good luck
Nov 21, 2008 | Zanussi ZJ1217 Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
297 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
