Question about Sony DSR-45 Mini DV VCR
DSR-45 When a videotape finishes playing, a latent, or ghost image remains on-screen and is visible over black. I believe this has something to do with a built-in image buffer. I see it in component and composite and S out, but not DV.
    Genius:
  • 1,139 Answers
Hello emvision,
This might be a problem where the tape when it stops it dose so at a point where the tape stops but it stops on an actual scene and dose a kind of pausing action as opposed to a stop condition (while pausing the video output amp is still active). In an actual stop the video amp is turned off. In digital once the stream is off it's off. This may account for the ghost image on the screen.
Posted on Jul 17, 2008
SOURCE:
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or traces.it comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD TV.it has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
thanks....
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
Hi. put in a mini-dv tape recorded on a sony z1 camera, the sony dsr-45p tape deck doesn't show any footage from the tape despite the camera had playback to show that footage was recorded. Using a windows...
the issue is probably related to the format the tape was recorded in. a z1u records in hi def (hdv) the dsr 45 is standard def ntsc. not compatable, play the tape in a z1 to recover
Oct 22, 2010 | Sony DSR-45 Mini DV VCR
AR-M355 Latent copies.
This make is not my specialty, but if the fuser's been replaced, then it can only be a drum cleaning issue causing that problem.
Dec 28, 2009 | Sharp AR-M355N Copier
I have a DSR-45. The door isn't working, but it's possible play the tape. what can i do?
door assy front rotary may be faulty
replace it at a sony service centre.
Nov 04, 2009 | Sony DSR-45 Mini DV VCR
Sony dsr-45 tape
It is:
Sony cleaning cassette DVM12CLD you can buy it from ebay at 15 pounds. click on the following link:
http://cgi.ebay.co.uk/Sony-DVM12CLD-MiniDV-cleaning-cassette-in-Blister-DVM12_W0QQitemZ370257959235QQcmdZViewItem
Aug 07, 2008 | Sony DSR-45 Mini DV VCR
Synchronize the DSR-45 as a 'slave' to an external unit with SMPTE Timecode
if i,m not miss understanding the problem is rec audio ng.if it,s, the posible cause are; 1;head dirty at the line of the tape causing data from head can,t write the tape optimal.for this problem you can clean the head carefull the head can easy broke., 2;if the picture having tracking posible the guide that bring the tape at the left doesn't fully at the track.for this problem at emergency you can try to push the left guide.
Sep 19, 2007 | Sony DSR-45 Mini DV VCR
Sony DSR-45 Lost Firewire Signal
Port's fried for sure -- that's a classic Firewire Port Burnout problem. Could be a cheap repair if you can take it to someone who's not afraid to get their hands dirty (soldering, perhaps). I don't know how integrated the port is to the unit (like on a laptop) so good luck!
Aug 24, 2007 | Sony DSR-45 Mini DV VCR
SLIDESHOW function
You can play the images in your camera on a TV or save them to videotape by connecting the camera with the bundled Audio/Video cable. Power up the camera in the PLAYBACK Mode, press the OK/MENU button to open the menu and using the arrow keys toggle up to begin the SLIDESHOW. You can even change the playback format in the MODE MENU. Press the OK/MENU button and using the right arrow key select the MODE MENU. Toggle down to SETUP, toggle right to enter the SETUP MENU and toggle up once to PLAYBACK SETUP. When you toggle right you will be offered four playback options: NORMAL, SLIDE, FADER and ZOOM. When selected you will get the following effects: NORMAL - Each image instantaneously replaces the previous image. SLIDE - The images are sequenced by sliding from right to left. FADER - The images are sequenced via a lap dissolve. ZOOM - The images are sequenced by zooming in to black and zooming out from black.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Sony DSR-45 Mini DV VCR Logo
75 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
