Question about SanDisk Sansa e250 MP3 Player
Music Help Alright, so I've had my Sansa for a while and all but I've been having problems lately. I only am able to put about 45 songs on it and no more. It says that memory is full but there is absolutely nothing else on it but the songs. Can someone help me?
  • 8,596 Answers
Reformat
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
Cannot get music on or off of MP3 player.
The 260 you can remove the screws on back cover and remove the battery and replace to reset, not sure on the 250, you might also want to go their website and download the latest firmware updates.
May 05, 2009 | SanDisk Sansa e250 MP3 Player
Cant delete music
Connect your sansa to the computer and then explore the drive and delete . also empty the recycle bin not to occupy space from your computer storage.
melnavz
Jan 23, 2009 | SanDisk Sansa m230 MP3 Player
My Sansa e250 wont let me put songs on it.
The songs are in the wrong format - you will have to load songs in mp3 format or WMA's THAT HAVE TRANSFER RIGHTS
Jan 11, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250 2GB no work duplicate the song
Edit the ID3 tag of the files in full before reloading them to your player.
Sep 04, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip
Use Windows Media Player to transfer the songs downloaded from Limewire to your Sansa. The first time you open Windows Media Player, it will search the "My Music" folder for songs - this may take a few minutes. Mkae sure you have Windows Media Player 10 or 11. You can either move or copy the Limewire songs to the folder called "My Music," or go into Windows Media Player and change Windows Media Player's configuration so that it can read the Limewire downloads folder.
-Tha Mp3 Doctor
May 26, 2008 | SanDisk Sansa e250 MP3 Player
I can't put songs on my Sansa Sandisk e250....
copy your music to your music file in my computer. Select all music that you want to copy to your device and copy to e: drive. This should solve your problem.
Jan 03, 2008 | SanDisk Sansa e200 MP3 Player
My sansa e200
-Plug in your mp3 player
-Go into 'Limewire', select a song and go 'Locate file/Open Containg Folder', you should be in your folder with all your songs. or go 'My Music' and find your music files.
-Either select all your songs, open them with 'Windows Media Player' and transfer them that way.
-Or 'Open My Computer' then open 'Sansa e200' and drag the songs from where your songs are located [My Music] to the 'Music' folder in your Sansa e200 folder.
[MyMusic] Song.mp3 >drag to> [MyComputer/Sansa] Music.
Dec 26, 2007 | SanDisk Sansa e200 MP3 Player
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
Problem with deleting music
It might have reformatted the songs by accident. Just try to redounload the songs you want and dont download the ones that you wanted to delete in the first place. This happens a lot with Sandisk e250 mP3 players
Jan 02, 2007 | SanDisk Sansa e130 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
