Phillips lcd tv
I have sound but no picture
  • Donis Dec 05, 2007
    I have sound but a black screen (no picture). This TV is not old!!! Less than a year. What happened?
  • 52 Answers
Well if the Tv is not getting the 12 or 24 volts going to the inveter from the smps than it wont light the backlights.
Posted on Nov 14, 2009
SOURCE:
Sceen is on, sound is on,but imegen is not, this is a phillips 47' lcd tv can someone help me is like 4 years old
That could be a Tcon or a main board issue. Can you post a picture of the screen? also will need the model number. Please respond to this same post for further assistance.
Jan 01, 2013 | Televison & Video
Philips 42PFL7422D/37 42-Inch 1080p LCD HDTV Picture went out but still have sound. Any tips on how to fix it?
If the backlight of the LCD-panel does not function, (no picture) then Master and/or Slave inverter are defective. Inverter boards are screwed to both sides of the LCD display, if they have revision 1.2 boards then they will need replaced with revision 1.3 boards.
Feb 16, 2011 | Philips 42PFL7422D 42 in. LCD TV
I bought a phillips 32 flat screen 5month ago,and it has gone wrong,it works for 20 mins then the picture goes off the sound stays on
Tv is less than a year old call Phillips for warrenty repair.This tv have a 1 or 2 long boards,call the LCD inverter boards,it have problems,about to died.These 1 or 2 long LCD inverter boards are to help the LCD screen to have a backlight to produced a picture.That why u have dead pictures,but still have sound.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long LCD inverter boards for the replacement.
Sep 20, 2010 | Philips Televison & Video
Picture goes black, have sound, red light comes on at the on button, 60'' phillips tv
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
Mar 16, 2010 | Televison & Video
NO PICTURE OR SOUND ON MY PHILLIPS MATCHLINE LCD TV 15PF9936 PLEASE HELP!!!!!!!!!!!!!!!!!!!
make sure it has power at the outlet,then suspect a blowed fuse or dioed or flyback,etc.
Feb 13, 2010 | Televison & Video
Phillips LCD TV - sound but no picture
You probably have a bad inverter board or possibly power supply. Both can cause this problem.
Oct 12, 2009 | Televison & Video
Philips 42PFL3603 tv sound but no picture.
Hold a flash light to the screen after it goes off and see if you can see a faint picture. Sounds like your backlight might be cutting off. Repair can be expensive but some of the newer units don't require the entire LCD to be replaced.
Sep 27, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
No sound on the hd setting on my lcd phillips hd tv
look in the owners manual about installing devices or components--- sounds like you have something hooked up wrong that is not allowing the video and sound to work--- if that doesnt work--- try using a combination device and hooking the two items to it--then run that device's wires to the television
Dec 03, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Picture & sound shuts off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Oct 06, 2008 | RCA L32WD14 32 in. LCD Television
Sony Bravia with Phillps dvd player
The DVD player may have multiple output formats that can be displayed. Sounds like you have the composite output selected when you have the component output selected on the DVD player. Check the menu options on the DVD player and confirm they match the way you have the player connected
Aug 31, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
175 people viewed this question
Top Televison & Video Experts
Ekse
