Question about Nokia 6600
Memory card problem
When i insert the memory card my phone cannot open the menu it is not work in proper way it restarts automatically
  • 175 Answers
Yes it is really your memory card problem to solve that you must format your memory card by PC using memory card reader if you still can backup your images, sounds and files that is not corrupted its better backup first before you format the memory card. but if you don't have memory card reader try any internet cafe i now they have that or last is service center. ok!
peace!
Posted on Dec 01, 2007
SOURCE:
I want to fomat my memory
Hi Bappi,
Please follow these steps as this will only format phone memory.
1. Dial *#7370# and then it will prompt for security code of the mobile.
2. Enter the security code as 12345 which is default or code which you have set.
3. Then the phone will be restarted.
Note: This wipe all the data of you of phone including virus.
If you want to format only the memory card follow the steps mentioned below:
1. Go to Menu and extras and open memory card.
2. Press option and then sellect format memord card.
Prefered way of formating memory card is by removing it from phone.
Insert the memory card to card reader and plug it to computer.
Take a back up if necessary and then format.
Insert the memory card back to phone after formating.
This solves your isssue.
Thankyou
[email protected]
091-9916828137
Jan 05, 2011 | Nokia N70 Cellular Phone
My 6300 restarts automatically when i insert any memory card why?
hi
there are some phone that will restart when memory card is inserted automatically for first time. but make sure that your phone will support the memory card that u use. if still problem arises kindly try your memory card in other phone if it works properly means the fault is in your mobile. kindly format the phone and try it. this will fix your problem..
thank you
Dec 19, 2010 | Nokia 6300 Cellular Phone
Everytime i try to download music to my memory
try using a different USB port to put the Dynes reader into then insert the memory card in it once the dynes reader is detected by the machine, if still not being detected check the services window
in XP click start open the run window type services.msc in the list look foe Human Interface Device Access double click and change it to Automatic, then look for Plug and Play do the same set it to automatic, then look for Universal Plug and Play Device Host set it to automatic as well make sure that after you set each that you click apply then ok to make changes take effect, after you've done the automatic settings remove the dyne card reader restart the computer aftrer restarting then insert your mini memory card into the dyne reader then insert the dyne reader into a USB port on your computer, Hopefully this should work ^_^
Jun 04, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
Have a problem with start button
Im telling the solution step by step.It ll work . you dont need to go 4 the firmware v5.05 If ur phone restarted 3 or 4 times and switched off automatically.
Try this Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu [default security code:12345] {i know most of people have done this thing,but remember u have 2 go with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]between 470kb - 499kb.
Now surely ur 3110c working fine about 5 months. During these time u can1
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime. but remember below
DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times and automatically swiched off.}
Jan 14, 2010 | Nokia 3110 Cellular Phone
Nokia N70 automatically send messages which displays in outbox folder. It automatically takes number from my contact list & start sending message to that number whether their number is landline or...
Your phone is infected with HatiHati.A malware. It is a worm-like application that spreads via MMC cards. Once the worm copies itself to a new device, it starts sending SMS messages on its own. Here's the DIY cure:
Note: This will erase all data stored on your memory card and phone. Copy contacts from phone to SIM card. Make sure the battery is fully-charged before proceeding.
  1. Format your memory card.
  2. Navigate MENU > TOOLS > MEMORY.
  3. On the memory card menu press OPTIONS.
  4. Scroll to Format memory card.
  5. Once the formatting is complete, remove the memory card.
  6. On your phone dial *#7370#.
  7. Press Yes then enter your phone lock code. Default code is 12345.
  8. When the phone restarts, insert memory card the format it again.
Please let me know if you need further advice.
Nov 20, 2009 | Nokia N70 Cellular Phone
Computer does not recognize the M2 micro memory stick san disk
1. It means your computer is not able to access your phone!
2. Memory card seems to be working properly!
3. Try to reinstall the phone driver software on your computer.
4. Restart the system and check again!
please rate this advice if it helps...tc! :)
Aug 30, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Nokia 3110 classic Have the problem of restrart automatically?
its not a problem when insert a new memory card you need to restart the phone for it work fine. or this is what you should do, whenever you want to change memory card on your phone turn it off and insert the card the turn the phone on again. its a simplication. i think this solution will help you if apply it. thanks
Jul 02, 2009 | Nokia 3110 Cellular Phone
I have problem with my memory stick in w850
It should be a problem with your memory card slot in your phone. It could solved by dusting the inside of your memory card slot.
After trying this, please reply whether it worked.
Thank You
Nov 15, 2008 | Sony Ericsson W850i Cellular Phone
My M2 ScanDisk Memory Card is not working properly. What to do?
Hi there! That's sad to hear! Try to insert the card properly. If still it's not working properly just return it the store where you purchased it. Use the warranty to replace it or repair it.
Sep 30, 2008 | Sony Ericsson K550i Cellular Phone
Phone restarts
i have same problem, i format the memory card, now it works properly. If this way u can't solve ur problem then it means ur memory card is out of order. please change it.
[email protected]
Jun 27, 2008 | Sony Ericsson W700i Cellular Phone
Nokia 6600 Logo
46 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
