Question about OKI C5300n Led Printer
OKI C7300 Printer
Hi, I have a 020 FATAL ERROR on my OKI C7300 can you help?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 97 Answers
OKI C7300 Printer - moz-screenshot-1.jpg Unfortunately it's a Hardware problem.
If you bought it from a dealer, contact them.
Error 020
When an error has occurred in the controller board (CU) or the program Rom.
Resolution:
Replace the Rom Dimm, see chart below for the correct part number. If the Rom Dimm does not correct the issue, then replace the (CU) controller board. Please refer to the service manual for (CU) part number depending on the printer revision
Posted on Dec 07, 2008
SOURCE:
What is the problem on a okidata C5300 error codes 020
This code relates to a fatal error with the ROM. You may want to contact Oki # 800-634-0089 and see if they are willing to help.
Aug 14, 2014 | OKI C5300n Led Printer
Oki c7300 Fatal Error
all oki errors are fatal errors, there will be a 3 digit number that will tell what the error actualy is
Jun 02, 2014 | OKI C7300 Led Printer
Okidata C7300 Fatal Error 120
Service call 120: error
PU unit fan motor
1. Is fan in PU operating?
NO - Replace Fan motor.
YES - Replace engine control board (K7N).
2. Error reoccurs after replacing fan motor.
Jan 18, 2011 | OKI C7300 Led Printer
Fatal error 020: oki c5450
As far as 020 error is concerned it is the TNY on the controller board. If you take the controller board out (it's the board that the usb/network cable plugs into). You find 2 banks. Ones for memory, the other bank is your prom board they refer to as a TNY.
Aug 18, 2010 | OKI C5400 Laser Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Getting Fatal error 020 on my Okidata 7300 printer. How do I fix.
You could take the controller board and reseat the dimms. But the Rom Dimm is usually bad and needs to be replaced.
Apr 15, 2009 | Office Equipment & Supplies
161 fatal error C7300
Try this - WARNING - will reset everything to factory defaults
The machine must be put back into "Shipping Mode" in order for the consumable counters to reset.
In order to place the printer back in "Shipping Mode" do the following:
0.27c?openelement&fieldelemformat=gif
1. For the C72/74/92/94 models, hold the (1) and (5) keys down, for the C73/75/93/95 hold (0), (1), (6), and (7), while turning the printer power on. (Hold until "MAINTENANCE MODE" is displayed)
2. Press (0) five times until "ENGINE DIAG MODE XX.XX" is displayed.
3. Press the (2) and (4) keys simutaneously, "ENGINE DIAG LEVEL 3" should now be displayed.
4. Press the (5) key once, "LOCAL PARAMETER SET" should now appear on the display.
5. Press the (6) key three times until "FACTORY WORKING MODE" is displayed.
6. Once "FACTORY WORKING MODE" is displayed, press (3) once so "Shipping Mode" (Fuse Cut Enabled) is displayed in the bottom line.
7. Next press and hold (3) & (7) together, until "Shipping Mode" stops flashing.
8. Power the printer off and back on, now the printer will reset the consumable counters. ecblank.gif ecblank.gif ecblank.gif
Aug 30, 2008 | OKI C5300n Led Printer
Oki c7300
Error 051 is a CU fan error.
It is solved by first replacing fan then the CU board.
I would call the seller or 1-800-OKIDATA
If you're comfortable with a screwdriver I would take the cover off
and look at the fan to see if anything is obstructing the flow.
Mar 24, 2008 | OKI C5200n Laser Printer
Service Call 020 Fatal Error
Error 020 is a ROM dimm error, could be as simple as reseating/replacing Rom Dimm or a expensive main PCB, you need to get hold of a oki dealer, contact oki to find closest OKI repair agent.
www.oki.com
Jan 08, 2008 | OKI C9300 Led Printer
Fatal error 141
141 Drum Up/Down, Color: Magenta An error has been detected in your printer's Magenta Drum. Did you already get this fixed?
Jun 04, 2007 | OKI C7300 Led Printer
OKI C5300n Led Printer Logo
905 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
