Question about HP PhotoSmart 7350 InkJet Printer
Printer cartridge cradle is stuck-hp photosmart 7350
Hp photosmart 7350 with blinking yellow light only
  • 3 more comments
  • Anonymous Dec 14, 2007
    Print cradle is stuck
  • RETSY Feb 22, 2008
    Printer says cartridge is stuck, remove the jam, press OK. I did remove jam, pressed OK, but the carriage will not revert to the right side. I've tried unplugging it. What else?
  • allric41 Jan 27, 2009
    cartridge goes to home position make noise and a click then the amber light flashes lcd message (is Stuck) help
  • elyndrt520 Mar 20, 2009
    Have HP 5600 all-in-one. Inserted black cartridge into the color cartridge side. Now it is stuck, can't remove. Can you tell me how to remove it myself without having to take it into a shop? HELP........
  • Anonymous Mar 14, 2014
    I ALSO GET ERROR CODE 0310E5E8
I just had the same problem...and this is what I did to get it working...
Turn off your printer. Open the top. Push the cartridge thingie off to the side (if possible) and then take QTips and cleaned the silver bar the cartridge moves on. Got a lot of ink off of it.
Should run after that.
Posted on Jul 12, 2008
  • kellybs1 Oct 16, 2010
    Awesome! Worked like a charm :0)
I tried to change printer cartiridge but hit wrong button and the heads move and slipped the cradle head to a different location, now it says to clear the jam.
Posted on Feb 09, 2008
SOURCE:
Ink cartridge leaked inside HP photosmart 7350. How do I clean up the mess. I tried cleaning w/Q-Tip and alcohol but there's a lot of ink there. I probably have to clean it all before installing a...
Lots of Q-tips! I'd also use some small pieces of cotton cloth--be careful it doesn't leave strands of cloth in the bottom of the printer. I've had this happen and I just stuck with it until it got reasonably clean.
Oh--and warm water will work just fine. Most of the ink is water-soluble
Oct 26, 2011 | HP PhotoSmart 7350 InkJet Printer
HP920c cartridge light wont stop blinking, printer wont print
Please refer below for detailed troubleshooting of the specific condition:
PRINT CARTRIDGE light RESUME light POWER light Blinking Off On c00106873.jpg c00106862.jpg c00106865.jpg Problem
The printer top cover is open, or there may be something wrong with the print cartridge.
Solution
  1. Close the printer top cover.
  2. If the PRINT CARTRIDGE light continues to blink, continue with the following steps:
    1. Open the top cover. The print cartridge cradle will move and then stop.
    2. Locate the yellow arrow on the top of the print cartridge cradle. The yellow arrow points to a drawing of a cartridge that represents a symptom. Perform the task associated with that symptom.
    3. For a list of symptoms, refer to How to use the cartridge drawings under the top access door on a 900 series Deskjet .
May 12, 2010 | HP DeskJet 920c InkJet Printer
I have an hp photoshop 7350 with an error message of "Print cartridge cradle is stuck". Can you help?
Good day!Try to see if there is a foreign object that made it stucked..try cleaning the ink in the carrier of your cartridges..
feel free to ask..
mastergani
Mar 26, 2010 | HP PhotoSmart 7350 InkJet Printer
Fast blinking red light, message says cartirdge service station is stuck
Solution
Follow these instructions to adjust the clutch on the printer.
Disconnect the USB cable.
Press the printer power button to turn off the printer.
Disconnect the power cord from the back of the printer.
Open the top cover of the printer.
Remove the print cartridges from the printer.
Slide the cradle to the right side of the printer.
Locate the clutch on the left side of the printer.
NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal.
Figure 1: Printer clutch
Remove the rear access door from the back of the printer.
Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
Release the clutch and roll the wheels up two more rotations.
Reinstall the rear access door.
Reinstall the print cartridges and secure the latches in place.
Close the top cover and reconnect the power cord.
Turn on the printer.
Print a test page.
NOTE: If the printer continues to display a Print cartridge cradle is stuck message or make grinding noises, click "contact hp" on this page for more support options.
May 26, 2009 | HP PhotoSmart 7660 InkJet Printer
Print cartridge cradle installation
how does the color catrigde for ip 1800 doing?
May 12, 2009 | Office Equipment & Supplies
All lights keep blinking!tried unplugging and reinstalling.Dead?
If the Resume c00121686.jpg light continues to blink and the print cartridge cradle does not move to the right side of the printer, try these solutions:
  • Remove and reinstall the print cartridges. Verify that the print cartridges are in the print cartridge cradle before pushing them forward into position.
  • Verify that no obstruction prevents the print cartridge cradle from moving freely on the rod.
  • Verify that the vinyl tape has been removed from each of the print cartridges.
If the problem persists, contact HP Customer Care.
Jan 14, 2009 | HP Photosmart C3180 All-In-One InkJet...
Hp photosmart printer 7350
Turen the machine off
Unplug it from the wall
open the paper jam door and gently push the paper roller upward until it clicks.
close the door.
Plug it back in
Wait a few minutes
then turn the printer on and see if the carriage moves.
This is a simple general reset of theprinter and sometimes it will help with this sort of problem. Let me know if it helps or not.
Jul 25, 2008 | HP PhotoSmart 7350 InkJet Printer
solution for...
" CARTRIDGE SEVICE STATION IS STUCK " with a blinking red light...
it's a bit difficult...just fixed it today....
first of all...u have to be sure that your service station is clear from any other old ink that maybe dried....that stuck the movement of the service station...
if it doesn't work again...folow the next step...
1. u have to pull out the service station... ( the difficult one ..!!! )
2. under the service station, there is a small motor....just find a new one and change it..
it works...
.....i found this new motor in an old hp printer's service station that i have...
thank u
Jul 04, 2008 | HP PhotoSmart 7760 InkJet Printer
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e [email protected]@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
Print cartridge cradle struck
packing material like spanch remove form printer
Dec 01, 2007 | HP PhotoSmart 7350 InkJet Printer
HP PhotoSmart 7350 InkJet Printer Logo
1,599 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
