Question about Car Audio & Video
Jvc kdg162 Have installed the unit and working fine, OTHER than I cannot find a way to store my setting. ie demo display off, and eq and balance settings. I set up my preferences in User and when I turn off the unit or shut off car and rteturn all settings are back to default! Any ideas?
  • 1 more comment
  • FSMA Dec 13, 2007
    My problem is related but just the opposite:.... When switched on, display always opens and stays in DEMO with changing displays. How can I revert back to factory setting?
    also, the switch on display does not show after I reset it.
  • Anonymous Jun 05, 2008
    I have exactly the same problem i thought the cd is like that because i brought it at a sale price. Every time i go in the car i have to set the settings (base.tre balance e.g) soon i turn the ignition off all the settings are lost even if it is for a split second i was thinking off returning it as is a real hassle doing this every time you turn the ignition on. The instruction that come with the cd are know help either, can somebody tell me how i can fix this problem.
  • Anonymous Jan 19, 2009
    No. I have the same problem after a empty Battery. But i have not removed or diabled the radio. .... On main Manual I found nothing!
I had this very same problem and just fixed it.
Turn on radio, Push the SRC button until the ILL comes on.
While that is flashing push either I/ K or stations up / down buttons
you will then see DE O will cancel the demo mode.
You can then go back and select the color you prefer.
Press and hold SRC button until ILL appears. While holding SRC
button down select ILL 1 for BLUE ILL 2 for RED. Display will flash twice
when set.
These directions (Turning Demo Off) are printed on the Table on Contense page
lower right corner.
Selecting color is under OTHER FUNCTIONS,
Good luck, be patient. I did it and I have big fingers.
Posted on Jan 08, 2008
    Novelist:
    Champion:
  • 218 Answers
Make sure you have hooked up your memory power wire to a source of 12 volts that does not go away when the ignition switch is turned off. I suspect that is your problem. Your main power wire will of course need to go cold when the ignition switch is turned off.
Posted on Dec 03, 2007
How do I get unit out of demo mode...it is stuck and will not turn off demo mode
Here you go
Turn on or turn off the display demo mode.
The console features a display demo mode,
designed to be used if the exercise bike is displayed in a store. If the demo mode is turned on,
the console will not turn off and the display will not
be reset when you finish exercising.
You can turn on or turn off the display demo mode.
From the settings menu, select Demo Mode. The
currently selected demo mode option will be
highlighted.
To turn on the demo mode, select On. To turn off
the demo mode, select Off.
Your manual is here.
http://www.sportsmith.net/images/product_support%5CProForm%5CPFEX013112%20-%20PROFORM%20LE%20TOUR%20DE%20FRANCE%20BIKE%5CPFEX01311.2-320509.pdf
Sep 19, 2015 | Proform Pro-Form Tour De France Spin Bike
How to set the color on my faceplate. It contnues to change color
You're stuck in DEMO mode. When you see stereo's on display at a store it is set to a DEMO mode that cycles through colors, functions, etc so that potential customers can see the different aspects of the unit. To get it to stop changing colors you'll have to go into the menu and turn DEMO OFF.
Aug 28, 2011 | JVC AM FM CD DET FACE CAR STEREO
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
I CANNOT SWITCH OFF THE EQUIPMENT ,AS SOON AS I GET TO SWITCH OFF THE HI FI IN A FEW SECONDS THE EQUIPMENT SWITCH ON AGAIN AND I CAN SEE THE WORD DEMO ON THE SCREEN
RTFM: Page 13:
"A demonstration of the display is shown if you have not set the
clock. You can reduce the power consumed in standby mode by turning the demonstration off.
While the unit is on:
Press and hold [–DEMO] until “NO DEMO” is
displayed.
Each time you press and hold the button:
NO DEMO (off) DEMO (on)
This is a 24-hour clock.
The example shows how to set the clock for 16:25 (4:25 p.m.).
1 Press [0/I] to turn the unit on.
Press [CLOCK/TIMER] to display “CLOCK”.
Each time you press the button:
CLOCK>>PLAY>>REC>>Original display
Within 5 seconds
Press [SET].
Press [TUNING (Up or Down)] to set the time.
The time display can be changed in one minute units by tapping
the buttons, and quickly by holding down the buttons.
Press [SET].
The time is set and the original display is restored."
Or under Troubleshooting Page 38:
"The display starts up even after the unit is turned off.
The demonstration feature (–DEMO) is on. Turn it off if it is not required."
If you need the manual go to
http://audio.manualsonline.com
register and get it for free.
Mar 25, 2010 | Technics SC-EH780 CD Shelf System
Sony CDX-S2210 CD Player stuck on demo mode , cant adjust volume eq, skip track or anything
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Jan 28, 2010 | Sony CDX-S2210 CD Player
Cant get it off demo mode lost the instructions technics sa-eh 760
1 Press [ê/I] to turn the unit on.
2 1 Press [CLOCK/TIMER, -DEMO] to
display "CLOCK".
CLOCK>FPLAY>FREC>Original display
2 Within 7 seconds
Press [SET].
3 1 Press [TUNING (X or W)] to set the
time.
tapping the buttons, and quickly by holding down the buttons.
2 Press [SET].
Jun 15, 2009 | Audio Players & Recorders
I cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
How to turn demo off kdc-mp3035
1. Be sure the unit is in the stand-by mode (ie: turned off)
2. Push the control knob towards FM or AM. Select the DEMO display
3. To set the DEMO mode, do this:
Press the control knob for at least 2 seconds. The demonstration mode alternates between DEMO ON and DEMO OFF.
Although it doesn't say, i would imagine you need to press the MENU button to exit this screen.
This information came from the instruction manual that I was able to download from the internet. Shoot me an e-mail and I'll forward it off to you.
Mar 09, 2008 | Kenwood KDC-MP3035 CD Player
Demo Mode
press and hold the mode button for more than five seconds. Then use the knob to scroll to "Default". This sets the stove to normal operation.
Dec 09, 2006 | Bosch HGS435UC Gas Kitchen Range
Car Audio & Video Logo
380 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
