Question about Draytek Vigor 2600We (Vigor2600WE) Wireless Router
Draytek Vigor 2600we
I have all the lights on the cables connect, The PC (running XP) can see the router but I cannot get it to connect to the internet. When I use the Router Tools v3.7.1 it all sets up but no icon appears. If I use V2.5.3 Quick Start Wizard is launched and reports No Router detected. What can I do?
  • 556 Answers
I do not have one of these devices however from the specs it is a combination DSL modem / Router that supports both wired connections to 4 ethernet ports as well as wireless connections. This device has configuration options that apply to the ISP side as well as the wireless side that could be causing issues. Lets try eliminating the wireless issues first. Do you have a computer with an ethernet port for a wired connection. If so attempt to connect to the internet using a wire to the ports on the wireless router. If this works we are assured the ISP connections and configuration are correct. If not I would suggest working with your ISP to get this working first. If this does work the next step will be to review the wireless configuration. If you got this new or from your ISP these settings may be known. However if you bought this used we may have some discovery to make this work. However we can address that after we determine the solution to the above issues.
Posted on Dec 06, 2007
How to change language from Chinese to English? help me please. Vigor 2920 Dual-WAN Security Router.
You need to update / upgrade firmware. The firmware can be downloaded here : http://www.draytek.co.uk/support/downloads
Mar 07, 2015 | Draytek Vigor 2920 Dual WAN Security...
Unable to establish wifi for windows 8 to draytek 2390vn
I have the exact same problem. I end up with limited connection. Same machine on Linux connects to the same network without any problem.
Feb 11, 2013 | Draytek Vigor 2930Vn Wireless N Router...
How can i set up my router?
The Draytek Vigor router supports USB-based Wide Area Network, or WAN, modems. It has four 10/100 Base-T ports, Network Address Translation IP packet filtering firewall, Demilitarized Zone and Virtual Private Network. The initial setup requires installing the firmware. Then, connect the USB router to the modem, in order to upload the firmware automatically to the modem.
Mar 07, 2012 | Draytek Vigor 2600VG Wireless Router...
Hi Team, I have a Draytek Vigor 2700 Router. I have redirected ports 80 , and 34599 to view my DVR cameras at my office. I have a static IP and i can successfully log into my DVR via HTTP port 80,...
It is an issue the Draytek and your phone.
Draytek displays as a web page. It uses HTML or XHTML
In order to see it on your phone it needs to be coded in XHTML Mobile 1.0
Jul 02, 2011 | Draytek Vigor 2700 Adsl2/2+ Router 2 Vpn /...
How to set up a internent connection for 2 companies both with independent lines using a single broadband connections and DrayTek V2930VN Wirelss Router/Firewall with VoIP.
The easiest solution is to use a simple router (wired-only) to connect to your Internet Service Provider.
Run a cable from one of the LAN ports on the router to a wired/wireless router, to provide access for the first company's computers.
Run another cable from another of the LAN ports on the router to a wired/wireless router, to provide access for the second company's computers.
May 05, 2011 | Draytek Vigor 2930Vn Wireless N Router...
How do i make my broadband connection secure on my vigor 2600we
The general recommendations for securing a wireless router are:
1) Do not broadcast the SID
2) Use WEP or WPA encryption with a strong pass phrase
3) Use MAC filtering
Each routers admin screens are a bit different but the manual that came with the router should walk you through the steps to configure your router.
Good Luck!!
Apr 09, 2009 | Draytek Vigor 2600We (Vigor2600WE)...
Draytek Vigor 110 modem
There is no default username or password to access the Vigor routers. Reset the router to clear any previous settings from its memory. Default IP Address is http://192.168.1.1 Manuals and firmware is available from the device maker.
May 17, 2008 | Draytek Computers & Internet
Bad reception
If your old router has an option to become a relay for a specific Access Point.... most do not have that option unless its a 3rd party firmware
Apr 28, 2008 | Draytek Vigor 2600We (Vigor2600WE)...
Draytek Vigor 2600We (Vigor2600WE) Wireless Router Logo
226 people viewed this question
Top Draytek Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Draytek Computer and Internet Expert? Answer questions, earn points and help others
