Question about D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842)
Change from default
I have a D-Link DI-624, which worked fine set to Encyption, but after installing a new hard drive, I find the router will only work if it is set to default, I use internet to buy items online and worry about security.
I did not install hard drive it was done at a shop as Im not very technically minded, I did phone D-Link but they said I needed a network card but I already have a network card installed on my PC, to be honest I think the person on the other end of the phone just could not be botherd.
Can you advise me please?
  • missmuffit47 Dec 01, 2007
    Forgot to say i run Win XP home edtion
  • 556 Answers
I am going to make some assumptions here first is that the hard drive was added to or replaced in your computer by a store or by a friend. Is it possible that the installer altered your network card configuration eliminating the encryption settings required to be set in your computer for your wireless adapter card to connect with the router in your home? If so I would suggest reinstalling encryption in both your wireless router and to your computer for its adapter card as you did initially to get them working. I find it annoying too when service personnel change my computer's settings and do not set them back to their previous settings when they have completed their work.
I hope this helps.
Posted on Dec 06, 2007
SOURCE:
Seting router d-link airplus g+ tm 624
You can set up for that dlink router.Do this step.
Click start>open internet explorer and the address URL type http://192.168.0.1 press enter.
Username admin
password leave blank
For setting details click this link to download user manual guide http://www.dlink.com/products/?tab=3&pid=DI-624&rev=DI-624
Hope can help you.
Thanks using fixya.
Jul 11, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
When i run wisard it ask about old passworld
This FAQ is for the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-774, and DI-784.
Step 1 Open a web browser and enter the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter.
Step 2 The username is admin and the default password is blank (nothing). Click OK.
Step 3 Click the Tools tab and then click Admin to the left.
Step 4 To change the administrative password, enter a new password in the Admin section.
To change the user password, enter a new password in the User section.
Step 5 Click Apply then click Continue to save the settings.
Note: If you forget your password, you can reset the unit to factory defaults.
Click here for instructions.
Nov 02, 2010 | D-Link AirPlus DI-524 Wireless Router
We reset the d-link di-624 wireless router and now it will not let us sign back on without the username and password which we do not remember. how do i factory reset the router?
Hi, when you reset your router the password is reset to default, and that default is admin admin. And to reset it, at the rear is a small hole in the hole is a button, remove from the power, and depress the button for a few seconds, then connect the power and try to logon again with your browser using the default settings.
It is also all explained in your user manual link below...
http://www.retrevo.com/support/D-link-DI-624-Wireless-Routers-manual/id/420ci368/t/2/
Aug 18, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Network is "Hidden"
Try a router reboot.
1. Unplug the Router
2. Shut down and restart the laptops, unplug the XBOX for 20 secondes even though its working.
3. Replug the router.
If this doesnt work you can try resetting the router to the factory settings.
Follow the link below for step by step resetting procedure.
http://www.geckoandfly.com/5890/reset-d-link-router-factory-settings-and-default-password/
Jun 13, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Re-installing DI-624
Access the configuration page of your router by default its 192.168.0.1, Login to the Dlink page by default the Username is Admin and Password is Blank and then reconfigure your router for Internet connection.
Dec 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link DI-624 AirPlus Xtreme G 2.4GHz Wireless router not connecting using the wireless point on it
The DHCP on your router isn't working properly. You should perform a hard reset on the router by finding the reset button on it. Take a pen or other small pointy object find find a tiny hole on the router. Press and hold this for 20-30 seconds. This will reset to factory settings and the password to the router will also be reset to its normal default.
Reconfigure the router as if you had just bought it new and it should work properly this time
This is from a DI-624 Router, and should be very similar to yours:
Oct 16, 2017 | D-Link AirPlus Xtreme G DI-624S Wireless...
D-Link DI-624 won't work!
hi thanatos
try resetting the router back to default settings by holding in the reset button for 30 seconds this is found on the back of the router you will need a small pointed pencil or paperclip to do this
Feb 08, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Internet Connection
try a cross cable between di-624 and westell dsl router.
Jan 12, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Factory setting
The following is for the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624S, DI-754, DI-764, DI-774, and DI-784 routers. To perform a reset, please follow steps below: Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset. Step 2 Hold paper clip down for 10 seconds and release. Note: Do not repower unit during this procedure. Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset. Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults. If you have the European version of this router, this procedure may not work. Please consult the D-Link office near you. D-Link USA does not support the European version.
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842) Logo
67 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
