Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
Service required Parts inside at end of service life??? How to reset RX600
    New Friend:
Hi you all... Yes i did reset my rx600 by pushing the black copy button and power on.
it did reset the system! and works fine now!
I did suck as much ink i cood with kitchen towel on the ink pads and it works fine.
till now hi...
Posted on Sep 18, 2015
Thank you grazie mille....funziona alla grande!!!
Posted on Sep 10, 2008
It works so far ..... thank goodness
Posted on Dec 06, 2007
I seem to have fixed my own question. Thanks to the "silly girl" pressing buttons. On the Epson Stylus Photo RX600 try pressing the stop button, color button, B&W button and the On button all at the same time. It starts up without that fatal red indicator with a message saying the ink tray has been emptied. Press the OK button and things are back to normal, I hope!
Posted on Dec 01, 2007
  • Wendy Dodson Mar 15, 2013
    Thank you ,i will try this.Sounds more likely to reset than the other way i tried
Parts inside in my printer are near the end of their service life
A Service Error where you get a message telling you that "Parts inside your printer at the end of their service life, contact your dealer for replacement", or "Parts inside your printer require maintenance or replacement, call your service company", is normally a Maintenance Request Error. The maintenance request error is actually a Waste Ink Ink Pad Error and usually your remedy is:
1. Replace the Waste Ink Pad/Pads with a new one/ones (many people ignore this one, and they just follow #2)
2) Reset the Internal Waste Ink Pad Counter by using SSC Utility
Download from this site http://www.ssclg.com/epsone.shtml and follow instructions.
I hope this information will be helpful. Thank you for using FixYa!
Jun 08, 2011 | Epson Stylus Multifunction Inkjet Printer/...
We're getting this Service Required message - Parts inside your printer are near the end of their service life. See your printer documentation. What part are we needing to replace?
the parts most likely to be replaced with such a message are the waste ink pads. (sponge pads that collect the ink that is used for print head cleanings). these pads are difficult to reach inside the printer (full dissassembly is necessary) and doing so is a VERY dirty job. i suggest contacting a repair center near you.
Sep 11, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson RX600 service required. How can i reset the printer and get rid of the error message?
I just had this same error message pop up on my RX600 yesterday. There is a utility that you can d/l from the Epson website to reset the counter at the link below.
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
The reason the service message pops up is that it is telling you that the waste ink pads are near the end of their service life and probably saturated with ink. You should still clean the waste ink pads or ink will eventually run out the bottom of your printer and create a big mess. If you do a Google search for something like "rx600 waste ink pads" there are some how-to discussions on doing this yourself. I'm going to clean mine later today.
They say it's not hard to do and you don't have to disassemble your printer, just use a toothpick or modified paperclip to remove the pads after you park the cartridges in their "replace ink cartridge" position and unplug the printer. A more detailed procedure can be found with the Google search.
Aug 25, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
It's is asking service required,
parts inside your printer are near the end of their service life. This is message is coming, how can i do this problem, please tell me
Sep 06, 2009 | Epson STYLUS R230 InkJet Photo Printer
Epson r230
Apologies for the late response but this is a pretty standard issue ie: your waste counter in the printer memory has triggered a warning.
To solve it you need to either
  • Get the printer serviced which will replace the printer pads and reset the counter.
    OR...
  • Modify your printer to redirect waste ink to an external waste ink tank. Then use a suitable software utility to reset the waste ink counter.
For the latter approach, you can use the SSC utility to handle the reset and there are various kits out there pre-built or you can fashion a tank yourself if you're feeling adventurous..
Hope that helps..
Martin
Jul 04, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
The RX600 does not print anymore. The screen on
This message indicates that your waste ink pads are full and require replacing. Replacement is costly, messy and requires the printer to be taken completely apart. Most often the counter has "jumped" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue is available from the Epson web site, please read this link:
Please take a moment to rate this solution. Thanks.
Apr 01, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson printer -parts at their end of life!
Where can I find ink pads for my Epson Stylus Photo Rx600 ?
August
Doodlehyde@juno.com
Jul 29, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
EPSON STYLUS PHOTO RX600:HARDLY VISIBLE PRINTING/SCANNING
when i turn on the printer this message appear to me ( services required parts inside your printer are at the end of there service life see your printer documentation for details
Mar 04, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Sylus Photo RX600
press the on, stop, color & b&w buttons at same time and hold them down for awhile......seams to reset everything....good luck
Oct 23, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
458 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
