Question about Eclipse CD3422 CD Player
Help Message CD3422
I have the cd3422 eclipse receiver and its says help and then shows 7a90418 on the screen...i forgot which cd was my security cd but figured it out...it let me try 5 times before the help thing popped up. I was gonna see if there was a way to start my tries over before i had to get the microprocessor replaced.
  • highlandspla Oct 15, 2008
    my eclipse says CALL 800
I have the same problem,if you solved that problem would tel me how!
Thanks a lot!
Posted on Nov 04, 2008
Purchased my car used and have no idea what the key cd is. Battery went bad so now I have no cd player. Display shows serial # of unit. Any way to fix this?
Posted on Oct 03, 2008
SOURCE:
How do I find a manual for an Eclipse Stereo model #CD3422 Date June 2002
Hello there.
Closest I could track down is CD3424 Looks like it MUST be pretty close to 3422.
Downloads are on this page
http://www.eclipse-web.com/us/download/manual/manual/index.html
Sep 22, 2014 | Eclipse CD3422 CD Player
Eclipse cd3422 not working only shows 7AB00025
You need to enter the code or the Cd that you chose to be your key. The unit is security locked.
Aug 25, 2009 | Eclipse CD3422 CD Player
Error codes
unplug radio to run antenna now radio screen display's SEC help then numbers come up at the bottom of SEC . This is for a eclipse3000
Oct 02, 2008 | Eclipse CD3422 CD Player
AUX In for Eclipse CD3422
yes it does, it's part of the CD changer plug.
Here's ->LINK<- an adapter for the iPod on EBay.
Regards
Philip
Sep 18, 2008 | Eclipse CD3422 CD Player
Error
The manual states
1. " An (ERR_) message will appear, then change to a flashing (DISC), then the CD will be ejected."
You will have 5 uninterrupted attempts to insert the correct CD.
2. After the 5th incorrect attempt, the display reads (HELP)
3. If (HELP) appears on the display, press button (6), then the (FUNC) button, and hold them for 5 seconds.
4. Press the (FUNC) button. You will have 5 more attempts to insert the correct disc.
IF AFTER 10 TRIES, AND IF THE CORRECT KEY CD HAS NOT BEEN INSERTED, THE DISPLAY READS (CALL 800); THE UNIT MUST THEN BE RETURNED TO ECLIPSE TO BE RESET. CONTACT ECLIPSE DEALER OR CALL (800) 233-2216.
Jul 19, 2008 | Eclipse CD3422 CD Player
Eclipse CD3422
When you first set up the stereo, you inserted a security CD which was a CD of your choice. You need to just place that same CD in and it should restart your radio
Aug 12, 2007 | Eclipse CD3422 CD Player
CD3422 Aux Mode
hook it up through the back in the 3.5 mm jack.
Jul 16, 2007 | Eclipse CD3422 CD Player
Set up problem on eclipse cd3422
call 1-800-233-2216 (Fujitsu ten) and they will assist you in the removal of the security code for a $25 charge. the number being displayed is probably the serial number of your unit. If you can remove your radio the SN will be on a tag.
Dec 31, 2006 | Eclipse CD3422 CD Player
Eclipse CD3422
The microprocessor has gone bad and needs to be replaced. Take it to an authorized repair center and they'll help you out ;)
Jul 29, 2006 | Eclipse CD3422 CD Player
Eclipse CD3422 CD Player Logo
176 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
