Kodak EasyShare CX7530 Digital Camera
Problem for Kodak EasyShare CX7530 Digital Camera
My kodak digital camera wont stay on!
By babipassion2 on Aug 16, 2009
I have a kodak digitial camera and i bought it about a year ago... used it twice and couldnt find the adapter to charge the battery... i just found it and charged it and it turned on.. and i can take pics and everything but once i turn it off... i cant get it to turn back on again
unless i charge it
it doesnt say the battery is low or anything... and the charging light works fine since it blinks when its charging and stops when its charged idk what to do
Solution #1
posted on Oct 12, 2009
Not Rated)
leepania
Rank: Wiz  Kodak StaffKodak Staff Cameras & Camcorders  Expert
Rating: 84%, 72 votes
What model is your camera?
For cam w. non man. produced batt. type
Pls. use: AA non-rechargeable lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Use the camera w/o the memory card
For cam w. man. produced batt. type
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt.
If not you will need to order a No power repair.
Kodak Digital Imaging Support Centre can be contacted on any of the numbers below:
UK 0870 243 0270
International Toll line +44 (0) 131 458 6714
Was this helpful?
Yes
No
Solution #2
posted on Aug 17, 2009
Not Rated)
BillB-SA
Rank: Wiz  Kodak Cameras & Camcorders  Expert
Rating: 85%, 353 votes
Your problem could be the result of corrosion on the battery terminals inside the camera. Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, clean both ends of each battery, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Comments:
Aug 29, 2009
- This problem is normally due to corroded battery contacts. Remove the batteries and wipe the contacts inside the camera with a clean soft cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Once the contacts are clean, remove any specks that may have fallen into the battery compartment during the cleaning, clean the batteries, and reinstall them in the camera.
This cures the problem about 90% of the time.
Was this helpful?
Yes
No
Popular Solutions for Kodak EasyShare CX7530 Digital
Questions and Unsolved Problems for Kodak EasyShare CX7530 Digital
Do you recommend Kodak EasyShare CX7530 Digital Camera?
Answer
Answer
lens does not move when you want to take a snap, in fact it got stuck, all other functions are... (More)
Answer
Recently the quality of my photos has declined. Some photos are still great, then others are very... (More)
Answer
Then display stopped working today. It can still pics just not thru the lcd screen.
Answer
Can I use a 4gig card in this camera? How do I format the card? Kodak CX7530 Easy Share 5.0 Mega... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kodak EasyShare CX7530 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
