Question about Refrigerators
Refrigerator part wont get cold
A friend gave me a kenmore/coldspot fridge model 106.71184100 a couple of days ago. Plugged it in, freezer works fine. Lower fridge part struggles to get cold at all, temp around 52 degrees. Any common solutions?
  • Riggss May 21, 2008
    Food is frozen in the upper freezer but the lower part of the refrigerator wont get cold
  • flalady407 Aug 06, 2008
    frige not getting to 40 degrees andfreezer not freezing
    frige is a bottom profile freezer
Push in door switch and make sure the light bulb goes off
Posted on Dec 02, 2007
  • 447 Answers
Yes sounds like the freezer fan isnt working. Do you hear it?
Posted on Dec 01, 2007
  • joey  shearer
    joey shearer Dec 02, 2007
    No the only fan is in the freezer section. If you hear the fan than it must not be defrosting. Or the defrost water may not be draining proper, making the return air ducts from the refrig ice over. Remove the bottom tray in the freezer. If you find a sheet of ice below the tray than u may have found your problem
SOURCE:
Kenmore coldspot model 106-54592400. The refrigerator is not getting cold enough, has been hovering around 45 to 50. The freezer is working.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 10, 2010 | Kenmore 50522 / 50524 Side by Side...
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Kenmore coldspot side by side refrigerator - freezer fine. other
Good to see you put your model number down correctly. Do the lights come on inside when you open door? I noticed your refrigerator has a control board inside the fresh food section behind the control panel I want you to unplug the refrigerator and examine that board for burn marks or loose solder connections on both Sides. Then let me know what you find. Thanks, Sea breeze My email is [email protected] Web Site http://servicepartstec.blogspot.com/ Part Number for Control board is 8201528
Jun 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
HotPoint model HSS25GFTBB fridge warm freezer cold?
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Jul 07, 2008 | Hotpoint HSS25GFP Side by Side...
Kenmore Coldspot Model 71182101
I have the same problem. The refrig and freezer are cold but not freezing and not cold enough. I have a friend tell me it probably is the relay. His did the same and that was the issue.
Jan 09, 2008 | Kenmore 72073 Top Freezer Refrigerator
Refrigerators Logo
912 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
