Its a capacitor problem that is easily solved by a do-it-yourselfer.
Google dvp642 and c316 (location of the cap on the board). A simple
inspection will tell you if its bad and you can replace the cap out of
Radio Shack for a couple bucks. Im doing it to a player right now...I
have the bad capacitor out and just need the replacement. The bad cap
will be bulged up on the top. It looks like a black barrel w/ an
aluminum top. Its located on the main board that the power cable is
attached to. You will find forums which describe the repair and
replacement part in detail. Good luck!
iz found in my dealings the majority of these problems were either caused by the power supply printed circuit board, or in lesser extents the main printed circuit board. check the capacitance of the capacitors on the power supply. good luck.
my standby/on button just began flashing and now, will not turn on. I've checked to make sure it is...
(More)
my standby/on button just began flashing and now, will not turn on. I've checked to make sure it is getting proper power and it is. the device was working flawlessly last night.
my start light is blinking and no buttons work. i have a dvd stuck in my dvd player that i need to...
(More)
my start light is blinking and no buttons work. i have a dvd stuck in my dvd player that i need to get out. any suggestions?
