It's not that easy. The SP-H03 accept VGA input through the D-Sub connector. Mac book does not have this output directly. So you need another piece of adapter for the MAC Book to provide VGA output. It would come out from your Mac "Display Port /orThunderbolt port". Another way is to use a USB to VGA adapter for Mac.
Dear Sir: You must explain them, such as you did with the error, The PROM, EPROM, was corrupt, there are NOT anything we can do for fit it. However if you wan to RUN the software calibration for diagnose, troubleshooting, do it.
I have the exact problem. My machine is 3 days old. I am also getting this H03, H13, H24 error. I called the 1-800 number for the Treadclimber TC20 and they informed me that a handful of machines were sent out with a bad control board. I am waiting for a replacement board.
this error code means that there is something wrong with the laser lens most portable dvd players over time get weak motors or lenses you may try to take a small cloth or cotton ball and move the lens back and forth from the spindle to the end then place it as close to the spindle as you can then turn it on and you might be good to go! if not then you have a bad motor and may have to replace it! hope this helps!
H03 is a mech problem if I remember you need to take the bottom cover off and remove the mechanical assy (laser chassis) then you need to clean the worm gear (this is the gear that moves the laser back and forth) even the littlest amount of dirt will jame this gear and make the unit go into H03 Mode
Hi the code HO3 relates to their being a problem with the laser you could try using a lense cleaner and see if its just dust or something like that failing that its going to be getting the laser replaced let me know if you need further assistance. If you type in your search box this DVD-LS90 Portable DVD Player with screen HO3 then search this will then list a load of sites that cover your dvd player and will also tell you what that error code means have a look and if you was getting it repaired then their should be a few sites that are selling the parts you need ok
I have had this problem for 2 years, mech.is hanging up. mine was replaced.... 3 weeks later same problem. I take out the disc and very GENTLY press one direction or the other to free it up. works great for a whole movie or several movies in a row. A small amount of electronic lube helps, just make sure you don't get it near the laser head or it will mess things up. Just clean it off real well if you get some on it.
