I fixed this problem in my DVP642 by replacing a capacitor on the main power board where the power chord hooks in. Take the top cover off (after unplugging player). You'll be able to locate the bad capacitor on the circuit board located on the very right. Look for location marked c316 on the circuit board. A bad capacitor will be bulged up on top. The capacitor you're looking for will be a black barrel shape with an aluminum top, this aluminum top will be bulged up or leaking on the circuit board. Replace this capacitor by desoldering the two leads into the board and replacing with an identical part you can pick up at Radio Shack for a couple dollars. My repair for this identical problem was a success. The blinking light is the tip off for this particular problem on these Phillips models.
my standby/on button just began flashing and now, will not turn on. I've checked to make sure it is...
(More)
my standby/on button just began flashing and now, will not turn on. I've checked to make sure it is getting proper power and it is. the device was working flawlessly last night.
my start light is blinking and no buttons work. i have a dvd stuck in my dvd player that i need to...
(More)
my start light is blinking and no buttons work. i have a dvd stuck in my dvd player that i need to get out. any suggestions?
