Question about Linksys Wireless-G WRT54G Router (DSLSWRT54G)
LINKSYS Wireless-G WRT54GS V7
When I plug in the router before I connect any wires to it, all of the lights are lit up green and do not change if I reset the router or connect any wiring. Also, the modem does not recognize the router being connected. This problem happened while it was fully functional and in use at the time and has not been working since then.
Is it garbage? The router is fairly new and would hate to see my money go to waste.
Thanks
  • Anonymous Dec 01, 2007
    This router also will not let me connect to the internet, worked for a while then stopped.
    Scholar:
  • 70 Answers
Knowing Linksys products fairly well this an axact problems that I've had in the past. Sorry to say this but the internal circuitry has gone bad. If you call linksys thewy will do a cross ship exchange. Meaning if you give them a credit card they will send a new unit and you send the older unit. If your out of warranty they still sometimes do this out of courtesy. Thier tech support number is (800) 326-7114.
For the second guy, if the lights stay constantly lite it's the same problem
Jeff
Posted on Dec 02, 2007
SOURCE:
Delete information on drive
There are 2 ways to reset the information on the Linksys WRT54GS.
One is by using its web interface and the other is by using the reset button on the back part of the device.
The reset option is the easiest and fastest, you will need a small pin/paperclip as it is a inset button.
Follow the procedure below:
1) Turn on the device.
2) Press and hold the reset button for at least 10 seconds.(IMPORTANT: Make sure that the Power LED of the router is blinking when you press the Reset button. This indicates that the router is being reset properly.)
3)After pressing the Reset button, unplug and re-plug the router's power adapter.
Oct 02, 2013 | Linksys Wrt54gs V7 2.4 Ghz 54 Mbps 4-port...
I have been running a Linksys BEFSR41 version 2 wired router for over 5 years without any problems. My wife is a teacher and her school p[urchased new laptops recently so I decided to go wireless. Got on...
I think the most likely problem is that both routers are using different IP address ranges and won't allow data to pass between them.
I suggest you use only the Linksys wireless router.
Nov 17, 2010 | Linksys Wireless-G WRT54GS Router...
Can connect to internet directly through modem. When connected through Linksys WRT54GS router, all lights are ok on both modem and Linksys--including internet. (Have had this router for 2 years...no...
As last resort you might want to use a JTAG cable and debricking programming software. If your router is brikced or you want to change the firmware this cable can do it. The cable will connect to your parallel port and your wireless router so you can repair your router. They are about $5.95.
Jan 11, 2010 | Linksys Wireless-G WRT54G Router
How to lock a links router modle wrt54g v7
Are you trying to secure the wireless network ? For this you will need to access the router set up page. Do you have any computer connected to the router with the cable ? If not then you will need to connect the computer to the router. Click Here for step by step solutions
Nov 18, 2009 | Linksys Wireless-G WRT54GS Router...
I would like to know the firmware upgrade for the linksys wrt54gs v7 router w/ speedbooster
latest firmware is Ver.7.50.6. you may download it from here: http://www.linksysbycisco.com/US/en/support/WRT54GS/download
Jul 14, 2009 | Linksys Wireless-G WRT54G Router
My linksys connection sometimes shows that another wireless network by the name of "Green Table" is within range and my connection strength seems to become lower when the "Green Table network" appears. My...
I would go into your settings of your router and change your channel.  It sounds to me like you are getting outside interferance with another router on the same channel.  If you need more assistance, please let me know and I will help you as much as I can.
May 31, 2009 | Linksys Wireless-G WRT54GS Router...
Wlan light is not lit on my linksys WRT54G wireless route.
ar eyou trying to get wlan? or just wondering about the light ? if you have wlan and no light its just a bad bulb then if its not enabled then enable it
Mar 21, 2009 | Linksys : WRT54GS Wireless-G Router W/...
WRT54GS router stopped working
try holding down the reset button which should be behind or under the router for 30 seconds, still holding down the reset button turn the power off for 30 seconds, still hoding the reset button wait more 30 seconds. After that your router should be in the way it came.
Feb 24, 2009 | Linksys : WRT54GS Wireless-G Router W/...
Linksys WRT54GS not working
  1. First you may need to check if the WLAN or Wireless light on the router is on.
  2. Try connecting your ITouch to a different wireless network.
  3. If you can borrow a wireless ready laptop from a friend, then borrow one.
  4. Check if the laptop will be able to detect a wireless signal from router.
Please update me about this matter.
Nov 16, 2008 | Linksys Wireless-G WRT54G Router
You just needed to Connect ur router to the computer
1>open Internet explorer type 192.168.1.1 and then Enter
2>Leave the username blank and password admin(lowercase)
3>then in linksys page change the Local IP of the router to 192.168.2.1 and then power cycle the network it will not create any problem later
Mar 08, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54G Router (DSLSWRT54G) Logo
136 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
