Question about Sansui VRDVD4005 DVD Player/VCR
Sansui dvd recorder SAN0901
Standby light is on all the time but unit will not do anything at all. will not respond to remote and red light will not extinguish unless unit is unplugged???
  • christbc Jan 18, 2008
    Thanks for your help. I had checked the 5 volt rail and it was low. All other voltages were as specified. The capacitor C4 looked fine, but on substitution the 5 volt rail was restored and the unit works fine. thanks again
Hi Christbc,
This sounds like a major power supply fail. Fortunately most of the voltages are present on the power supply when the unit is in standby. The ones that are controlled by the STANDBY/ON button are 12V and 5V which can be measured on connector CN3. The STANDBY/ON control line to the power supply board is labeled P/L on connector CN2. In the standby mode the 5V line should be 0V, the 12V line should be 0V and the P/L line should also be 0V. In the on mode the P/L line rises to 3.1V, the 5V line goes to 5V, the 12V line goes to 12V. All the other voltages should be approximately as listed on the board whether in STANDBY or ON. (+FL= -19V and -FL= -22V). The probable fault is the capacitor C4 which filters the 5V line and it can be found near the rectifier diode D2. and the transformer.
Good luck.
SteveO
Posted on Jan 16, 2008
Turn the power on. to get rid of the red light you need to press the timer/rec button on the remote until it turns off. the red light means it is programed to record.
Posted on Jan 10, 2008
2 Suggested Answers
SOURCE: Sansui SAN0901 DVD Recorder - Power Problem
Hi Pandjoy,
I have been struggling with the same problem and almost rebuilt the power supply before finding the solution. In my case it was a faulty capacitor-C4, next to the diode D4. Replacing C4 and the machine performed as new. I hope this helps. Cheers
SteveO
How do I set the recording speeds on the vcr without a remote control?
Unfortunately, you need the remote control to do this. You can get a replacement remote with all of the features here: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12937528570080&smodel=VRDVD4001&brand_pn=SANSUI_VRDVD4001 . There are a couple of other versions of the Sansui VRDVD4001 and their remotes are also available from remotes.com. Search on the model but not the brand name.
Even the timed recording menu which doesn't need the speed button doesn't have a button on the front panel of the unit.
I wish that I had better news.
Dec 30, 2010 | Sansui VRDVD4001 DVD Player/VCR
I would like to make a copy from my video tape to a DVD How do I do it?
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. Remotes.com often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
BTW: the manual is available here: http://www.managemylife.com/mmh/owner_manuals/26967/SANSUI-DVD-VCR-Combo-L0311311?brand_name_search=sansui+VRDVD4005 .
I hope this helps.
Nov 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
Dvd player/recorder wont work
I had the same problem with my sansui san0218-160 dvd recorder, i found a capacitor had failed on the power supply board, i replaced the capacitor and it now works perfectly.
Feb 20, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui vrdvd5000 no manual no remote anyone know how to record vhs to dvd
I believe the VRDVD4005 manual (which is the same as the VRDVD5000) is available on a Sears sponsered website called managemylife.com. I hope this helps you. The customer service number should be on the back of the unit to order a remote.
Jan 31, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
SAN0901 Manual
again hope this helps!
i'll check back to see if you need more help
electech
Oct 22, 2008 | Sansui VRDVD4005 DVD Player/VCR
Sansui vrdvd5000- need manual
Hi seemaile,
All my searches resulted to negative which leads me to believe that there no readily available user manual for the Sansui VR DVD5000.
Sorry.
May 26, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Recording
hey- i have the sansui vrdvd5000 and didn't have a manual (or a remote). i just ordered one here- hope this helps!
http://www.orionsalesinc.com/miva/merchant.mvc?Screen=CTGY&Store_Code=OSI&Category_Code=VRDVD5000
Apr 21, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui San0218-250GB.
i had the same problem with my sansui san0218-160 dvd recorder. i found the power supply board inside the case had failed, so i replaced two faulty capacitors on the power supply board and reassembled the recorder, it`s working like new again. hope this may be of some help.
Mar 30, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui DVD Recorder Model HDR 120GB
put Dvd back into unit- press DVD on remote- DVD light will light up on the unit- press "set up "button on the remote- a screen will come on - use remote arrows to go down to system set up- press enter- another add on menu apprears -use arrows on remote to choose "disc set up" press enter- another menu appears- go to "finalize" press enter - a pop up menu appear- choose "yes" and wait until disc finalizes- finished and usable in any DVD player. This is on page 27 and 28 in the manual. Have fun- DD
Feb 23, 2008 | Sansui VRDVD4005 DVD Player/VCR
Hi Pandjoy,
SteveO
Dec 04, 2007 | Televison & Video
Sansui VRDVD4005 DVD Player/VCR Logo
411 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
