Question about Acer TravelMate 4021WLMI Notebook
4021WLMi blue screen
I had a blue screen and my acer 4021WLMi reported corrupt sys32 files so I reinstalled using the restore set of disks and immediately was informed by windows one the dll's were now missing .right away I restored using my set of disks and all was fine for a couple of days then the blue screen appeared and it shut down. when I tried to start up again windows reported that some files were missing ,then after a short time the blue screen reappeared with a small message in the corner saying hard error. Does this indicate my hard drive is duff
  • 89 Answers
Is the message something like \Windows\system32\xxx missing or corrupt ? If so, you'll need to perform a repair: http://support.microsoft.com/default.aspx?scid=kb;en-us;Q314058
Posted on Jan 10, 2008
Cav i use e recovery outside windows to restore lost or corrupt sys32 driver files on my E4024 emachine p.c.?
If your recovery partition is intact, or made recovery CDs, then yes. The machine will be returned the state it was in when it left the factory. If you have a pre-owned computer, or else the computer was not originally purchased with Windows pre-installed, the recovery partition may have been damaged or destroyed in which case the procedure will be very much more complicated and difficult and perhaps expensive..
Be sure you have copied your data to another disk and have noted any downloads yo have made so that you can replicate what you want.
You might take this opportunity to test your hard drive for faukts.
18.December.2014
Acer will have the procedure on their website, and here is another version:
http://www.ehow.com/how_2337743_do-emachines-system-recovery-.html
Jun 07, 2014 | eMachines ET1810-01 PC Desktop
Tip
Blue Screen of Death
The stop error screen or bug check screen commonly called the blue screen of death (also known as a BSoD, bluescreen, or "blue screen of doom.
In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
Often, if you're lucky, the problem will resolve itself with a simple reboot and you may never have to worry about it again. More typically though, the BSOD is a harbinger of trouble and you may find yourself faced with another and another until you throw up your hands in frustration... but all is not lost.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This is if you are able to boot into safe mode (Press and hold the F8 key during boot up). This will ensure that all driver bugs are fixed and that all hardware has the correct driver. If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name. There is a neat program on the net that can fix this problem, it's called DriverFinder, you can get it here.
If this doesn't work or you can't think or find the corrupt driver you could use System Restore (If it is enabled) to go back to a time where you didn't get the error. To use the system restore utility, go to 'start/all programs/accessories/system tools/system restore.
Sometimes though the blue Screen of death can be caused by faulty or loose rame cards. Check that your RAM modules are inserted correctly and arn't clogged with dust.
After using the computer for a few months or years, the hard disk gets fragmented with temporary files, or fragmented files. This will result in slowness of the hard disk and may even result in a computer crash eventually. You can maintain your harddisk by defragmenting your hard disk and deleting unwanted files frequently.
If you see Fatal OE exceptions and VXD errors then it is due to the video card. To solve this reduce the video display resolution. You can do so by going to the control panel and display settings. Choose the correct screen resolution to match your monitor.
on Nov 14, 2010 | Computers & Internet
Wont run windows at all. Says: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
You have a corrupt registry and it needs to be replaced.
Doing a System Restore will do this. Since you cannot run it from the hard drive, you will have to boot from a Windows DVD.
Here is the procedure
Running System Restore in Windows 7 from your Windows Disk gHacks Tech News
You did not specify which version of Windows you have so I just picked W7 as an example. If you need more specific instructions, you need to give more specific information.
Here is an explanation of System Restore
System Restore Wikipedia
Mar 20, 2017 | Computers & Internet
How to factory reset without recovery disk
When you need to recover part or all of the files on your Acer Veriton M460 desktop computer, Acer makes it easy to do by offering a built-in recovery program called eRecovery Management.
This option uses clean operating system files, usually stored on a separate partition of your hard drive, to correct errors or return the system to its original factory settings.
You can also use this program to write separate hard copies of the eRecovery program onto CDs or DVDs in case of hard drive failure.
Create Backup Disks
If your M460 did not come with separate recovery disks, and many machines don't in recent years, you can create your own through "Acer's eRecovery Management" program located under the "Start" menu.
Click on "Backup," select "Create Factory Default Disk" and follow the on-screen directions.
The program will inform you of the number of CDs or DVDs you need and help you through their creation.
Recovery with Disks
To use your created disks for recovery, place the first disk in the optical drive and reboot the system. As it boots, hold the "ALT" key and tap "F10" repeatedly until the computer boots and you see a screen titled "Starting Acer eRecovery."
You will see three options for recovery: to factory default, from user backup or from CD/DVD. Choose the option you desire and follow the on-screen directions to initiate the recovery sequence.
Recovery from the Hard Drive
Since Acer places the eRecovery Management program directly onto the computer, you can run the recovery option while in your desktop.
Open the "Acer eRecovery Management" program under the "Start" menu and click "Restore." You can choose to restore the computer to factory defaults and lose all the personal data stored on the hard drive or only restore the operating system and leave your data intact.
Select "Yes" on the confirmation screen and then "OK" to start the program.
Recovery Vs. Restore
When performing computer problem solving, the term "recovery" is often used interchangeably with the word "restore."
In some cases, "recovery" can mean to simply correct problems, such as replacing corrupted operating system files with good ones.
The term can also refer to "recovering" the system to its fresh-from-the-factory state, which is what "restore" means as well.
Restore Drivers or Applications
Acer's eRecovery Management program also offers the option to reinstall drivers or applications, which could become corrupted or damaged over time.
This option allows you to replace the current drivers for your Windows operating system with the ones originally installed on your system.
Under the "Restore" tab of the "Acer eRecovery Management" program, click "Reinstall Drivers or Applications" to see the content list and select the files you'd like to recover.
http://supportforacer.iyogi.com/veriton/factory-settings-6.html
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq40.shtml
http://support.acer.com/product/default.aspx?modelId=477
Aug 26, 2013 | Acer Veriton Z290G Desktop Computer
Corrupt files windows system32 config system
The easiest way to fix corrupted windows system files is do an Acer eRecovery. On power-up, while the Acer logo is showing, press the Alt-key and hold it down while pressing the F10-key repeatedly. Wait while screen shows eRecovery loading. On the eRecovery menu, select restore of system software to factory condition. This will delete all user data from the hard disk and once the restore is complete, you will have to re-enter your initial system configuration settings.
May 25, 2011 | Acer Aspire One PC Notebook
Acer Aspire one D250. Upon starting up it says: windows root sys32.hll.dl is missing or corrupt, please install this file. Then when I hit enter it says: disk error has occurred press ctrl alt del to...
Your Windows installation has become corrupted.
You need to repair the Windows Installation with the aid of the Original Windows Disk. It is a tricky business, a computer technician will be able to do it for you if you get stuck.
Thanks
damnor01
Apr 13, 2011 | Intel Computers & Internet
Black screen when you on it
you should use your restore disks and reinstall the operating systems
Mar 28, 2011 | Acer Aspire 9300 Notebook
Hello, i have a acer aspire 6920g and it doesn't start up it does come up with stuff but it says, Windows could not start because the following file is missing or corrupt :...
As soon as you power up your laptop, keep tapping F8 until another screen pops up. Select reinstall windows / restore factory settings (Should be an option to reset your computer back to factory settings)
Any data on your computer will be lost during this process.....
This will reinstall the windows you already have on your hard drive and will not require a disk.
Hope this helps and please rate, thanks
Mar 19, 2011 | Acer Computers & Internet
Pc slow
Learn why is a pc running slow and how you can fix the issues from: http://www.whyismypcsoslow.net/
Feb 11, 2011 | Acer Aspire One PC Notebook
Blue ecreen error, system shuts down
Hi.
Blue screen means that an exception handling memory or a different computer resource has ocurred.
Blue screen error often occurrs when the sytem is corrupt.
Usually it is possible to fix the problem reinstalling Windows operative system.
Before reinstalling Windows you can try starting the system in safe mode (try F8 on startup). If system starts in safe mode, do a system restore to a recent date before having the problem.
Windows can be reinstalled using either factory recovery disk or a generic Windows setup disk in conjunction with a valid Microsoft licence number.
In case reinstalling Windows does not fix the problem, even if there are more hardware faults that can cause the problem, the first culprit is usually RAM memory.
Try reinstalling the system first.
Aug 08, 2010 | Acer Computers & Internet
Acer TravelMate 4021WLMI Notebook Logo
122 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
