Acer Aspire 5100 PC Notebook
Problem for Acer Aspire 5100 PC Notebook
Frozen keyboard acer 5100
By jetonrexhepi on Dec 01, 2007
I can not do nothing everything is froze and I am unable to perform any tasks,
thank you for your help
Comments:
Dec 03, 2007
- YEs I have tried with everything and so far no results at all,
please help out,
thank you
Dec 03, 2007
- Unable to use Keyboard and mouse, even F2 Bios and safe mode unable to perform any task at all, totally frozen, no option to boot from CD since primary device is hard drive to boot on,
Dec 03, 2007
- I told you I have tried everything, what I am doing now I have take off CPU, RAM, HHD, DVD keyboard, FAN, and I have put on refregeration to freeze the chip CMOS in order to deactivete the BIOS, I will freeze 24 hr. and try again, do you have any better solution, I had try to put with CV bootable without any results,
thank you in advance!
Dec 03, 2007
- first go ahead and take the CCNA and IT+Hardware and software and after that be able to respond to people,.
thank you
Same Problem
Jan 27, 2009
-   I have the same problem. I have emailed Acer before and they never replied =/, Go figure. -   daphaze1
Jul 31, 2008
-   Yes, I have the same problem. I purchased a new ACER 5100 in the month of Nov. 2006 and only after 12 months (seven days out my year warranty), I started experiencing some problems. The problems compounded where I started having problems with my mouse not working. I took my laptop to two computer repair techs including the place I purchased it- Circuit City to resolve the problem. I could not obtain help. I eventually called the mfg. who advised me to send it in. Unfortunatley I did not have the cost to repair a brand new computer at $450. That was the cost to take a look at it per the mfg. This has been a total nightmare. I could have spent my money more wisely on another brand of laptop when this company is acknowledged of the type of problems people are having. Now I holding a brand new computer and can not use it.....frustrated.
freida45-   falastonc
Jun 24, 2008
-   I have an Acer 5050 and suffered the same symptoms, in that I could work my way through the BIOS [F2] using the keyboard arrow keys, but as soon as I got into Windows, I could not type anything or use the pad to move the cursor. I also reloaded the O/S through my DVD backup, but again was stuck when completing the install as I had no keyboard capability to be able to type computer details in.
THANK YOU very much for your posts. You saved my bacon. Taking the battery out did the trick.
I am a bit perturbed that the vendor had nothing on its web site, or atleast I could not find anything.
THANK YOU again.
Graham
-   GrahamJ
Feb 05, 2008
-   I have the same issue with my Acer aspire 5050. It seems that when I boot up without the battery pack, it works fine. When I do boot with the battery installed (and AC cord plugged in) I get a frozen touchpad & keyboard at the xp user log on page. Please let me know of any solutions. Thanks!-   aiyuli
Jan 15, 2008
-   I have exactly the same problem with fix-the-prob. I charged my PDA and 5100 is locked. Only shutdown button is working. What a toruble laptop, I wikk send to a service today.-   anilo
Best Solution
posted on Jun 25, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
thank you
Solution #2
posted on Dec 11, 2007
Helpful)
poplock
Rank: Apprentice
Rating: 94%, 28 votes
This is a problem of Acer Battery. Should have a new battery will work normal. For temporary, restart in SAFE MODE, DISABLE Microsoft ACPI-Compliant Method Battery in Device Manager., Go back to the normal Mode. Keyboard and Mouse should work well. :-)
Was this helpful?
Yes
No
Solution #3
posted on Dec 05, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have Acer 5050 and same problem is there. I removed battery and used powercable directly. Keyboard and Mouse started working. Try it.
Solution #4
posted on Mar 12, 2008
Somewhat Helpful)
murpium
Rank: Apprentice
Rating: 79%, 5 votes
Do what 'Poplock' said. Disable "ACPI-compliant Battery" under "Batteries" in Device Manager. Then just put your battery back in. Works perfectly (I'm typing this now with the battery in).
To get to Device Manager, go to your Control Panel and it'll be in there. Press the plus next to "batteries" and right click "ACPI-compliant battery" and choose Uninstall. This will solve your battery problem till you get a new one.
Was this helpful?
Yes
No
Solution #5
posted on Dec 27, 2007
Somewhat Helpful)
zanadu2112
Rank: Apprentice
Rating: 81%, 4 votes
I have an ACER Aspire 3000 and the touchpad mouse and keyboard suddenly stop working after 30 seconds or so of use. As long as I'm not in windows everything will work fine. After using the recovery CD it still has the same problem. Through trial and error I found that if the battery is removed from the laptop it will work normally. I'm going to order a new battery and try the suggestion 'poplock' posted earlier and disable the ACPI-Compliant Method battery from the device manager.
Was this helpful?
Yes
No
Solution #6
posted on Dec 03, 2007
Somewhat Helpful)
hughv
Rank: Wiz
Rating: 83%, 315 votes
Does this happen every time you boot?
Have you tried an external keyboard?
Comments:
Dec 03, 2007
- Tell me what "everything" is.
How about Safe mode?
Does the mouse work?
Have there been other problems?
Try booting from the CD.
Dec 03, 2007
- Some laptops will auto-boot from the CD regardless.
Have you tried?
Dec 03, 2007
- That's an interesting solution that I've never heard of. Be careful of condensation.
Dec 03, 2007
- You're very welcome.
I see it's been a big help to you.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #7
posted on Jan 20, 2008
Very Helpful)
giorfino
Rank: Apprentice
Rating: 100%, 1 votes
I have an Acer Aspire 3000.  I also could not use the keyboard and mouse one minute after Windows XP started.  I was using an external keyboard and mouse via USB.  I took out the battery and started the laptop with just the power adapter plugged in (no battery) and everything works fine.
I am going to try to get a new battery and see if that helps.
Was this helpful?
Yes
No
Solution #8
posted on Sep 08, 2008
Helpful)
jgeraci
Rank: Apprentice
Rating: 83%, 3 votes
Resolution
1. Power down the laptop.
2. Unplug the power supply and battery.
3. Press and hold the power button for 30-45 seconds.
4. Release the power button and plug in the power supply.
5. Turn on the laptop.
6. After you are in normal Windows then put your battery in.
This is Acer's FULL POWER RESET. Acer still claims that they never heard about this problem but I was able to get this general fix information from them. If your problem is not resolved by this then Acer states it is a mainboard problem.
James
Was this helpful?
Yes
No
Solution #9
posted on Mar 18, 2009
Not Rated)
AWC2009
Rank: Apprentice
Rating: 0%, 0 votes
I have had the Aspire Acer 5100 freeze on me in random boot intervals of ~5min to ~1hrs (4hrs occassionally if really lucky). I found that changing the BIOS (F2 on boot) under Main - Video Memory from 256MB to 128MB and I just got 2 days consecutive service from my 5100. I'm convinced the issue lies with the Video (somewheres). Please post if this helps any you frustrated Aspire 5100ers. AWC.
Was this helpful?
Yes
No
Solution #10
posted on May 11, 2008
Not Rated)
adfag
Rank: Apprentice
Rating: 0%, 0 votes
same problem to my acer aspire 5050
Was this helpful?
Yes
No
Solution #11
posted on Feb 26, 2008
Not Rated)
anilo
Rank: Apprentice
Rating: 0%, 0 votes
The service changed my motherboard under the warranty. Mobo problem..
Was this helpful?
Yes
No
Solution #12
posted on Feb 25, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I also have an Acer Aspire 5050 and recenly found the same trouble. First my battery started to decrease its capacity abruptly, in a matter of days it was only lasting 18 minutes both in windows and linux. So I decided to discharge it completely and surprisingly during its discharge even with the monitor showing 0% charge after minutes, the battery provided approx. 1:30 hours with maximum brightness wifi and sound working. After this process the battery was recharged with the notebook turned off, and when powered on started with the same problem described above, windows completely unusable and linux freezing after minutes. Booting the machine without the battery only with the power chord give full functionality but if the battery is plugged, even after the machine is working, it freezes windows in a matter of seconds and linux in a matter of minutes after showing a lot of kernel warnings that I don't understand... Also in both systems even after plugging the battery what its shown is that none is present.
Yesterday I discharged again the battery and will try to recharge it with the machine turned on.
Hope this data can help any of you.
Solution #13
posted on Jan 31, 2008
Not Rated)
beany54
Rank: Apprentice
Rating: 0%, 0 votes
Same problem here found its overheating placed on packing to increase clearance from desk works a treat now dust build up inside i suspect
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 5100 PC Notebook
Questions and Unsolved Problems for Acer Aspire 5100 PC Notebook
Do you recommend Acer Aspire 5100 PC Notebook?
Answer
Answer
i'm using Acer Aspire 5735z N/B.gmail and google talk are not working properly in my system.if I try... (More)
Answer
i have an acer 3680. my web cam is not funtioning coz its saying hi speed usb needed. by web cam is... (More)
Answer
I have an acer aspire 5100. and i downloaded the bison program for my orbicam. it was working fine... (More)
Answer
is it possible to install a built in microphone into an accer 5517-1208
7 Other Users Have The Same Problem - Continued
Comment by fix-the-prob, posted on Dec 06, 2007
had the same problem with the same acer pc and I had to throw my laptop out the window (hardware, not software meaning...)
I even tried to pull off battery from the mobo to make the bios to reset with no results at all.
as far as I remember, I experienced this issue a few minutes after I plug the usb cable to charge my shuffle. Now, as you can easily prove, the OS starts (you cant log in, anyway), that means both the keyboard and the touchpad are correctly configured and recognized by the mobo, but they dont work....
So I kind figure out it would be an usb conflict or something like it, that prevents your keyb and touchpad to work
Anyway, got a brand new sony vaio now...
Comment by Smithy187, posted on Dec 04, 2007
I have the same problem, can anyone help....my acer laptop boots up windows but at the desktop my mouse pad/keyboard wont do anything..i can open in safe mode and it works perfect. Anyone have any solutions? i have tried a system restore to a month ago...its successful but still keyboard/mouse pad doesnt work.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 5100 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
