Question about HP iPAQ H2210 Pocket PC
Sd card can i use a 2gb sd memory card with the hp ipaq 2210 pda
  • 32 Answers
Yes u can..U can get it here just in case u wish t buy it online..
http://www.memory-up.com/Memory/HPiPAQ375_SD2GB.html?utm_source=Froogle&utm_medium=referral
Posted on Dec 01, 2007
SOURCE:
My new 4gb sd card does not register on storage display, and does not seem available to use
The official oprating systems of the HX4700, WM2003 and WM5, do not support SDHC card format. Since most 4Gb "SD" cards are in SDHC format (check the label on your card), the file format of your card is likely to be incompatible with the PDA. Get a 2Gb SD card, or go for a Compactflash card for 4Gb to 32Gb of storage space.
Jan 16, 2011 | HP iPAQ HX4700 Pocket PC
HP IPAQ H4150 + Memory Cards
Your HP IPAQ has a SDIO expansions slot...
which is a new technology.
so will have to use an SDIO card ...
this is a secure digital IO card.
hope this will solve the problem
Oct 30, 2008 | HP iPAQ H4150 Pocket PC
How do I setup my HP iPaq 2210 to access the internet with a WLAN-11b card? What are the steps?
First of all, you should install the driver for your wlan-11b card to your PDA. (There should be a CD given with the wifi card, or you can download in online through the card's brand's website, ex. .cab file for a Spectec SDW821 Wi-Fi Card) At this step, you should be carefull with the version of windows mobile on your device and the driver's version for windows mobile. After that, you should plug your wifi card to your PDA's SD slot, and your PDA will recognize it. So you can go to your settings, and there you can search for a wireless network.
Apr 15, 2009 | Compaq iPAQ H3630 Pocket PC
Just bought 4GB SD card that hx4700 does not recognise - help pse
Your slot in the iPAQ is a SD slot, not a SDHC slot - therefore it will not read the card. Your PC card is probably a dual reader. The SD cards look the same but are different. Have a read of this...
http://en.wikipedia.org/wiki/Secure_Digital_card
Dec 10, 2008 | HP iPAQ HX4700 Pocket PC
Wi-Fi SD card
Hey, id be happy to help :), the reason why your SD wifi card is not getting read by your pocket pc is because. The wifi card you have is probably have was made for a regular computer and is not compatible with your pocket pc. Id recommend for you to find a SD wifi card that is compatible with your pocket pc. And return the one you have now, thanks and I hope this helps!
Aug 29, 2008 | HP iPAQ H2210 Pocket PC
HP5550 Storage Card
The HP h5550 is a bit old PDA , and it cant recognize it.As i know , there is actually no way to connect it.Sorry.
May 09, 2008 | HP iPAQ H5550 Pocket PC
What's max mem size for ipaq 1950
Mem cards are added as storage cards and do not add up to your iPaq RAM.
You can use mem cards to add up space to install applications. (ie. it is something similar to installing a new Harddrive on your PC). However the physical RAM of your iPaq cannot be extended.
PocketPC programs have small RAM requirements so your PDA's built-in RAM will suffice.
As far as the maximum card size if I understood your question right, if your iPaq comes with Windows Mobile v5 or earlier, it supports SD cards up to 2GB and perhaps some non SDHC standard SD cards up to 4GB. If you can upgrade to WM6, then WM6 supports SDHC cards, so you can install >4GB cards.
Hope this helps.
Feb 16, 2008 | HP iPAQ rx1950 Pocket PC
HP ipaq rx3715
Have you tried other SD cards?  The box is uncheck for default install folder?  Maybe update the device.
Oct 13, 2007 | HP iPAQ RX3715 Pocket PC
IPAC 2210 + 2GB SD Cards
FYI - Use the SDIO update from the HP site, then do a hard reset and maybe even a couple os soft resets. Interestingly, it takes a while for it to appear (the SD Card). Even if you take it out and put it back, you will need 1 or 2 soft resets to get it to show up.
Sep 11, 2005 | HP iPAQ H2210 Pocket PC
Cannot see any SD card in expansion slot
The first thing to try is a soft reset while the card is inserted.
HP iPAQ H2210 Pocket PC Logo
107 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
