2006 Honda Odyssey Logo
Anonymous Posted on Aug 16, 2009
Panic alarm after using the jumper cable how to stop making noise
lordFord
Level 2:
  • Expert 175 Answers
  • Posted on Aug 16, 2009
lordFord
Expert
Level 2:
Answers
175
Questions
0
Helped
57178
Points
483
This is a protection feature to prevent disabling the alarm, if you have no means of stopping it with a keyfob, then disconnect the battery ground and reconnect it, that usually resets stuff to where you need it. check your manual first and make sure that I am not giving you wrong info on your battery as some are hooked up weird and have buttons and clips to get to do this stuff. (AKA BE CAREFUL!)
Testimonial: "damn sweet ty so much "
1helpful
2answers
2004 Honda won't start and when battery plugged in it won't stop honking
honda 02, no model told or sub model nor what transmission is there, AUTO/STICK/CVT or hybrid.
starter motor is dead.
1: battery not discharge (jumper cable starts fail and other batteries, fail. cables not loose;rusty.
2: small click heard the relay can be bad.
3: does PRNDL cranking work in park (A/T tranny)?) and fails too cranked on Neutral> PRNDL bad.
4: starter is bad if hot wired starters fail, (the acid test here) ask how. all techs know how. ask.
5: does this car have the IMMO, lamp showing IMMO failing? (immoblizer?) is this with IMMO keys?
lost the spare IMMO key?
head; lamps work ,key on and off????????
any other things electric failing? brake lamps.?
Car alarm reset?
1. Unlock the car manually. If the alarm remote is not working, use the key directly. Often times opening up the door will stop the alarm. If the driver's side door won't unlock, try the passenger door.
Turn on your car. Put the key in the ignition, and turn the car on. If this doesn't turn off the alarm, try turning on and off the dashboard lights a few times without revving up the engine.
Utilize common tricks. Factory car alarms have some simple reset protocols to help turn off an alarm. Most of the tricks rely on using the key in the door; simply put, a lot of factory car alarms have a door sensor, so working with the door might be the go-to for a quick fix.
Put the key in the driver's door and turn it twice to the right, then twice to the left. Then insert your key into the ignition and start the car.
Turn the key into the unlock position and hold it for two seconds before opening the door.
Disconnect the battery. If the alarm is still sounding after the initial troubleshooting, you'll want to silence the siren as quickly as possible. Car alarms rely on the electronic component of the vehicle, and disconnecting the battery should both silence the siren and reset your alarm. Open up the hood, locate the battery, and with a wrench, remove the negative terminal. Then reconnect it after a minute has passed.
If it is more easily accessible you can also unplug the wiring harness that connects to the car's horn or siren. If the horn or siren gets unplugged it can no longer make noise.
5
Reset the alarm unit. Locate the alarm and transmitter system; refer to your owner's manual for the exact location. Hit the reset switch or turn it off and on.
6
Remove the alarm fuse. This should both silence and take the alarm out of commission until the fuse is replaced. Find the alarm fuse in the fuse box. Remove it, and put the fuse in a plastic bag. You can store it in your glove compartment for safe keeping.
If you cannot locate the alarm fuse right away, remove fuses to see if the alarm will stop. Doing this will not cause damage to the car, but make sure you return the fuses after you've determined they are not for the alarm.
Some car alarms, when tampered with, prevent a car from starting as an anti-theft function. If you remove the fuse and cannot start the vehicle, you will have to take the car to a mechanic or dealer.
7
Press the "panic" or buttons on your keychain remote to stop the alarm. Because the "panic" button can sound the car alarm, it can also stop it. Pressing "unlock" or the "trunk" button can stop the car alarm because it disarms the car's security system.
8
Seek a mechanic if problems persist. If none these reset methods work, try speaking with a mechanic or dealer. If they can recognize the issues over the phone, the fix might be simple. However, further diagnosis might be needed in person.
https://www.wikihow.com/Disconnect-a-Car-Battery
Panic switch
The alarm is armed if keyfob is used. So you must use the fob to disarm alarm first. So someone can not unlock and open door without keyfob or alarm will be set off.
Wont start when key in ing. and turning on than cutting off if battery dead
factory alarm, when manually unlocking the door the lights flash & horn usually go off & the car will start & shut off within a second or 2. Have 2 96 jeeps that do it the panic button on the keyless entry is the only way to shut it off. If the battery has died & a new one is installed it trips the panic mode as well. If the battery is dead but vehicle starts with a jump but shuts off soon after jumper cables are removed, the alternator is bad & cant keep the computer powered up & will shut down the vehicle. A little more specific with symptoms will make diagnosing much easier.
Alarm won't stop sounding
Hook the battery back up. It may of shut off. If not the battery in your fob may be dead. Wait for your husband to come home and use his.
Panic alarm will not turn off.
I read about one guy who had the factory specs on this as an electrical problem.
2helpful
2answers
Honda civic 2008 - panic button on the key
Placed jumper cables on the car to try & jump alarm sounded pressed the unlock button & was then able to start car without any problems.
Panic Alarm
panic goes off.... have the dealer reprogram it and make sure the function of it is proper.. if the reprogramming does not work the module will need to be replaced like all other malfunctioning modules.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
