Question about Canon DC210 DVD Camcorder
Initializing disc I put a disc in (Verbatim mini DVD+R DL) into my camera, it runs the initializing for a minute or so and then when I go to tape sonething it says that it can not read the disc - check the disc....I did all the things that the manual said to do when that message appears, but still no luck....am i using the wrong disc??
    Scholar:
  • 91 Answers
Yes - you're trying to initialise a +R DL.
Two problems
1. The DC210 only takes - format DVDs
2. You only need to initialise DVD-RW discs (see page 57 of the manual)
By initialising the DVD+R you have written to it once. having done that, you cannot write anything else to that disc. I find it easier to use DVD-RWs so that I can re-use them.
Good Luck.
Posted on Dec 13, 2007
SOURCE:
My Verbatim DVD +R DL disc burned on my NEC 2510A DVD-RW will not play in a desktop DVD player but will play the computer it was burned on. The computer is running Windows 7.
It;s possible that you may have left the disc open or re-writable. Check this first.
The settings will be located in the software you used to burn the disc. Easiest would be to start a new burn session and read the available settings throughout the window prompts. It may also be located in advanced settings, if you don't find it this way.
Jun 14, 2011 | NEC ND-2510A DVD±RW Dual Layer Burner
What kind of blank DVDs do I use to copy an old VHS video tape to the DVD? I have the Sony RDR-VX530. When I put a DVD in, I get an Error message saying that I have the wrong DVD.
According to page 30 of the operation manual, the following information may help;
DISCS THAT CAN BE USED IN THIS RECORDER:
4x-speed or slower DVD+RWs
2x-speed or slower DVD-RWs (version 1.1, 1.1 with CPRM) (Content Protection for Recordable Media)
4x-speed or slower DVD-RWs (version 1.2, 1.2 with CPRM)
16x-speed or slower DVD+Rs
16x-speed or slower DVD-Rs (version 2.0, 2.0 with CPRM, version 2.1, 2.1 with CPRM)
2.4x-speed DVD+R DL (dual layer) discs
(when using DVD+R DL discs, see the instructions supplied with them prior to use)
4x-speed or slower DVD-R DL (dual layer) discs
DISCS THAT CANNOT BE RECORDED ON:
DVD-RWs (version 1.0)
DVD+RWs that are not 2.4x-speed compatible
8 cm discs (mini-DVDs)
DVD-RAM (any speed/any version)
DVD-R DL (dual layer) discs in VR mode
A free pdf copy of the manual for this model can be downloaded online.
Hopefully that provides some insight to your question.
May 25, 2011 | Televison & Video
The camera doesn't take mini dv tapes from sony or verbatim.
cannon only take cannon tapes sony and cannon never shared there tape size. you can only use cannon dv disc
Jul 28, 2010 | Canon GL1 Mini DV Digital Camcorder
HP dvd640e not recognizing DVD+R DL
6/25/9:  While this external HP DVD640e burner was listed as a NEW drive - "new" meant never used. A check with HP techs told me the unit was a 2005 factory closeout and the dual layer disc required for it is a 2.4 speed disc. I bought a 2.4 speed DL disc and it works perfect in it.  As far as seeing a CD when a DVD was installed is presumed also the fault of having the wrong speed disc in it (that lot of Memorex DL discs I am also having trouble with elsewhere too). Double-checking my profiler, it does give speed as 2.4x as the burner's profile. Alas, the problem was my newness to the DVD technology. A slap to the forehead and move on.
Jun 19, 2009 | HP dvd640e DVD±RW Dual Layer Burner
Using Verbatim DVD-R DL on Canon Camcorder 310 DVD
Some computers will not play mini dvds. You will need to check with the computer manufacture to be sure.
Jan 18, 2009 | Canon DC310 DVD Camcorder
Canon Help!
my camera no image for record and picture
Feb 02, 2008 | Canon DC40 DVD Camcorder
VHS to DVD DL disc help.
use the DL DVD-RW, - are good for videos and playing on a DVD player. any brand i think will do.
Jan 31, 2008 | Computers & Internet
HP dvd 740 doesn't recognize when blank discs are put in
Check IDE cable connection. You might need a new IDE cable. I had the same problem, until I did the aformentioned. Hope this helps.
Oct 06, 2007 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Canon DC210 DVD Camcorder Logo
182 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
