Question about Nokia 5300 Grey Cellular Phone
My Phone Stopped Working...
Hi every one my phone got problem the problem is that it was off suddenly and when i toke it to work shop the said that u need to change the battery when i changed the battery it is still the same but one thing after one day i can on the phone its working for some hours only i don't know what happened to it any one can tell me what will be the solution for this problem.
  • 175 Answers
Hi there i think the problem of your phone is the flex cable, most common problem of 5300. goto service center ask them if they have a parts to replace of your 5300 flex cable.
peace!
Posted on Dec 01, 2007
SOURCE:
How do i turn it on
If you're having problem of turning phone ON, the first thing to check is changing the battery pack,it might be drained and overused so you need to replace a new battery.another step is changing the charger,might failed to supply power on your battery and may result to drain the battery as well.
If this method never works,it's better to bring it to any mobile service shop near you for a complete diagnosis and troubleshooting the phone.
Good day...
Jul 13, 2011 | Motorola Mobility ROKR E6 Smartphone
I have a Blackberry and it was working fine-then all of a sudden i have a white screen with a message that says "ERROR 102" and "RESET" below that. I tried removing the battery several times and that didnt...
Hi, the problem you are having is with the phones firmware you will need to take this phone into a phone shop and have the phone flashed and the firmware re-installed, the problem with this is you can only have it done at a phone shop as they need to install all the software back on the phone and the other problem is that this will wipe the phone so you will lose anything on it.
you can back it up if you have the leads to your computer and the correct pc suite for your make of phone if you dont have this just ask the phone shop to back it up for you.
their is no other way of doing this as you cant get the firmware and re-install it yourself the phone shop will charge you for doing this but it will be cheaper if you go to one of those independant shops instead of one of thos bigger branded ones.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 19, 2010 | Cell Phones
Engine giveup
I own a Mercedez E 200 petrol 1999 model also caleed the 210 model. I got the AC cooler replaced as there was a leak. I started the car and came home. the next morning the car did not start as if the battery was down but I find that the lights are working and even the horn is working.
What could be thw problem > if I am to replace thw battery what snould be the Ampearage of the battery /
Will some body please rely very urghent [lease
May 24, 2010 | 1999 Mercedes-Benz E-Class
Hi have had my nokia 6280 for 2 and a half years now...replacing it soon but need it to function for another two months! problem is my battery started taking forever to charge and then stopped charging...
hi thanks for using fixya!!
On this kind of error, even if you had to change the battery or even the charger, perhaps the power supply internally is already damaged. Charging for more than 2 hours is a sign of something is not good and after that still shutting down. I recommend that you bring your phone to a Nokia Care Center or any service center to further check the hardware parts.
Regards.
May 15, 2009 | Nokia 6280 Cellular Phone
How can i solve the problem of low usage of battery packup?
Friend, since it appears that way eventhough the batt is new. As a mobile phone technician i diagnose base from my experience that the problem of your phone is not the battery but the power supply I.C. called CCONT. It is needed to be replaced or resolder especialy if it is shorted.You need mobile technicians to solve this problem. good luck
Apr 29, 2009 | Nokia N70 Cellular Phone
Sudden phone shut down.
better u change your battery and try....
Aug 28, 2008 | HTC P3300 Smartphone
My Mobile has a Powering problem and it doesn`t work because it was connected to my PC via USB and disconnected suddenly
contact nokia or a local phone shop to find out where to get it repaired.
www.nokia.com
You can try removeing the battery for 30minutes and trying again.
Jul 26, 2008 | Nokia N73 Cellular Phone
Mi ph is lock
hi i can help you nad give you the master code that will give you acess to the phone this code only works of the phone is asking for the code when you switch it on and also it wont work if the code has been entered wrong more than 5 times if it has then you will need flash lead and unlocking software witch would cost more than the phone.
But if you want the master code then i need your imei number its located on the back of the phone under the battery and looks like 1244567/135/1454254 its 15 numbers long once i have this i can generate your master code ok
Mar 20, 2008 | Nokia 6230
Nokia 5300 Grey Cellular Phone Logo
29 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
