Question about Sony PlayStation 2 (PS2) Console
About installing my cd/dvd player to my console
I have cable television and everything is connected up but i am have trouble installing my dvd to my console unless i disconnect some wires. I need help in order to see where i missed.
  • Anonymous Jul 19, 2008
    I have connected the dvd to my television. The dvd powrer button goes on and off. Cannot play dvd. Call Comcast the problem is with the dvd not cable tv.
  • 709 Answers
This is a bit confusing. You cannot hook a CD/DVD player up to the PS2 console. If your trying to figure how to hook a PS2 console and a CD /DVD player up to a AV system. you need to hook the PS2 Yellow, White and Red cables to any input. Not just a DVD or CD input. Yellow is Video you need that. Hook the red and white to the same selected input.
Posted on Dec 02, 2007
Trouble connecting my insignia 32in.Tv To my DVD player
Yes you can use Just the red,white and yellow cable from your dvd player to the make sure you have it connected correctly...sometimes its easy to confused the yellow and white connections. make sure your tv is turned to Input that you have used for connecting the cables on the back....such as...input input 1 on your tv....or if it says dvd...then select dvdv on yoru tv..You can use a HDMI cable...just plug HDMI from your dvd player to your tv and select HDMI on yoru tv..Good luck
Mar 08, 2015 | Insignia IS-LCDTV32 32 in. Television
Wii playback on games etc is only green and blue other colours
Sounds like a faulty cable or a loose connection. Check to make sure everything is connected snugly from your Wii to your television. Also try plugging the cables coming from your Wii into another available connector on your television if you have one available. Otherwise it's most likely the cord that connects the two if your tv displays other systems, such as your cable/satellite or dvd player, correctly.
Dec 01, 2009 | Nintendo Wii Console
Movie has no red color only green and yellow
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Sep 30, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Can not make the instalation betwen my tv and my dvd player
Most DVD players today have only RCA jacks for video and audio outputs, and don't have RF (channel 3 or 4) outputs. If your TV doesn't have AV input jacks (either too old or just not supplied on your model) you can't connect the DVD player directly. You'll need to get an RF converter to make the connection.
An RF converter costs about $15 and you'll find them where you can buy TVs. The converter takes the video and audio signals from the DVD player and creates a channel 3 or 4 output signal to your TV. If you don't have the cables already, make sure to get them too. You need a "dubbing cable" (RCA plugs on the ends, usually color-coded red, white and yellow) to connect the DVD player to the converter input jacks and an RF cable with "F connectors" on the ends for the output to the TV. Often the dubbing cable comes with a new DVD player, and the RF cable with the RF converter.
If this takes care of your connection troubles, please take a moment to give my solution a good rating. If I've missed something and can be of more help, please post a followup comment.
Mar 31, 2009 | Symphonic ST4819 19" TV
Connecting my DVD Player to my Digital Converter Box
The jacks from the player go to the same colored jacks on tv. Then after jacks are connected, tv must be on channel AV or Input. that is the channel used by the jacks.
Feb 01, 2009 | Coby DVD-224 DVD Player
DVD Player not working
Go to menu. Select inputs. Assign input 1(or whatever input you connectedthe dvd to) as DVD. Then exit menu. Press the input key, scroll over to DVD. I reccomend using a component cable with a digital audio cable, if you do not have a DVD player that has an HDMI connection. You will find that a blu-ray player will be much more satisfying for the television you have. Basically by hooking up that old dvd player to that tv, is the same as hooking an 8-track to a $2,000.00 stereo. It will work, but the quality is going to suffer! Good luck, and believe me. It is worth the extra money to get a blu-ray player. It will play all your old dvd's and blu-rays. That way you are getting the full potential of your set.
Dec 22, 2008 | Mitsubishi WD-60735 Projection Television
Panasonic Viera 37 inch Plasma won't read DVD player
does the cd/dvd player have component hookups or are you just using HDMI cable, lots of tv's are having trouble with the HDMI protocol, I only use component cabling, it has HD capability up to 1080i resolution
Mar 16, 2008 | Televison & Video
RCA CONSOLE TV will not work with DVD Player
what is the model of your tv and the method in which you are trying to connect the dvd (ie rca cable, component, composite, hdmi) and do you hear audio
Dec 21, 2007 | Televison & Video
Hooking up a cd player
I'm assuming you mean a DVD player, not a CD player? 1. You can get an input splitter (basically an A/B switch for the cable), and connect to that, manually switching between the two sources. 2. You can replace the VCR and the DVD player with a combination DVD/VHS unit. Although it would seem logical, it is unlikely that you can hook the DVD player to the VCR, since the VCR will refuse to let the signal pass though it, as part of its MacroVision copy protection. (This is the same sytem that prevents you from recording DVDs onto VHS tapes.)
Feb 18, 2007 | Zenith B25A74R 25" TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
Sony PlayStation 2 (PS2) Console Logo
87 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
