Question about Garmin nuvi 350 GPS Receiver
Countries i have a garmin 360 espana is loaded on the sd card but i cant set a route in spain
  • 174 Answers
Go to the wrech symbol, tap, tap map, tap about, see the spain map. Is it checked, if not check it by tapping it.
Posted on Jul 30, 2008
No detailed maps found that support routing
reason being you may not have an SD card inserted with maps otherwise your maps have been deleted. try running the map update on the unit and it should reinstall the maps for you... if the SD card is not missing you may have a faulty SD card or SD card slot.
May 18, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin nuvi 360 can't read sd card
Make sure you format first the sd card and then the maximum giga byte is 2 mb and the minimum is 16 mb.
Jun 09, 2009 | Garmin NUVI 360 GPS Receiver
Device not reading sd card loaded music
try putting sd card back into a pc and check that the write protection is turned off. also if it has a write protection switch on the side of it it will need to be off. failing this. you may need to check what format the sd card was formatted in . it will need to be ntfs formatt not fat32. if it is fat32 ,save whats on it re format to ntfs then reload your files. try again.. cheers Phixxer.
May 24, 2009 | Garmin NUVI 360 GPS Receiver
Need more memory for complete route, which had before upload
you should be able to buy a sd car to increase the memory.
May 13, 2009 | Garmin Nuvi 660 GPS Receiver
How do youcess your sd card on the garmin nuvi 200w series please
i lost my card for my garmin nuvi 200w series do i really need it
Mar 21, 2009 | Garmin nuvi 200W GPS Receiver
Garmiin nuvi gps,
The device uses SD cards actually. They will not however work with TOPO maps or Bluechart. They are primarily for loading media or city street maps for other country's.
Jan 14, 2009 | Garmin 010-C0495-00 TOPO Canada - Manitoba...
Garmin 330 GPS using abroad
In order to use the C330 in foreign countries, you need to purchase the maps for those countries and insert the SD card into your unit. You will then have to select the proper maps to use on the unit. These maps are available for purchase at
As far as getting around closed roads, your unit will automatically recalculate your route if you are unable to take the suggested route. You can purchase updated maps, but I do not believe this will help you will roads closed for repair.
Aug 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi 300 - SD problem
I believe your current location is somewhere in UK/Ireland, which means the Nuvi's last/current satellite fix is not anywhere within Spain/Portugal. If you need to use the maps features of that country where you're not physically there with the Nuvi, the Nuvi must be in Simulation mode first. Fold down the antenna to switch off GPS (not device) and enter Simulation mode.
Then, scroll the map screen (combinations of zooming out, browsing, and zooming in to the spot) until you find the location you want to simulate (it must be within the maps coverage). Then, tap 'Set Loc' at the bottom of the screen. At this point, as far as the Nuvi is concerned, this is the GPS location where you are at. Then you may proceed with Address Search, etc. using the other map's database.
Jul 26, 2008 | Garmin Nuvi 660 GPS Receiver
SD Card slot Garmin nuvii 260
I have found that waypoints, routes and directions work only when I load it on the unit itself as opposed to the SD card. The SD card works more like an expansion slot for pictures or maps.
When you open up Mapsource you'll see the map on the right and the pane on the left, above the pane there are 4 tabs (Maps, Waypoints, Routes and Tracks). As you select a map or create a waypoint, route or track. It will put a number in parenthesis which will increase in numbers as you add an item corresponding to each category, for example if you create a waypoint. So once you have done that, click on the TRANSFER tab in the Menu selection bar and choose SEND TO DEVICE. A window will pop up that will say...Device: with a drop down menu if your Garmin unit has an SD card in it, if not it will just show the Garmin unit. Then right below that there will be a section that says WHAT TO SEND with 4 check boxes that will say Maps, Waypoints, Routes and Tracks. Make sure that you have selected the Garmin unit, not the SD, and the waypoints, routes or tracks you want to send. I hope this solves your problem or at least points you in the right direction...
Jun 20, 2008 | Garmin nuvi 200W GPS Receiver
Mapsource routes
Hmmm, I think the routes are supposed to be on the device memory, like trip logs. You should have like 130 MB of free storage on the device...
Jan 06, 2008 | Garmin zumo 550 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
67 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
