Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Sony KDF-50WE655 While watching TV we heard poping sound (more like someone snap a piece of hard plastic in two) then screen went black, and heard unusual rapid metallic popping/zapping sound, similar to the sound one hears when turning on flourescent lights coming from the back of TV.  I went and investigated the sound, is in the back of TV center lower bottom, saw some what like a capacitor glowing with electricity. It does sound like the lamps is busted but not sure. does anyone have any suggestion?
  • sonykdf50 Dec 01, 2007
    is me again, we still get audio from TV.
  • sonykdf50 Dec 02, 2007
    thank that is the problem...buying lamp to replace...but not sure why the zapping sound coming from back of TV...i can see glowing capacitor !
    Novelist:
  • 192 Answers
It sounds like the lamp is definitly bad.
Look at it and more than likely it is broken.
The lamp is located in the front of the set. The bottom front is a cover that has a dial on each side of the back of the sets that can be turned by hand (counter clockwise) holding the front panel in place.
There is a metal strip that is holding a door in place and can be removed.
The lamp is being held in place by a screw that needs to be removed with an allen wrench.
There are several places that you can buy lamps online.
This is a link that this site advertises that has do it yourself instructions:
www.AMatterOfFax.com Reply to this post if you have any questions and I will respond.
Posted on Dec 02, 2007
SOURCE:
KDF-50WE655 TV Picture hard to see very dark, several different colors of spots
if your seeing spots on the screen consider it may be time to either have someone look at it (suspect it will turn out to be a bad light engine) or retire and replace it.
May 01, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I replaced the lamp and my tv still don't work
i have a sony kdf-50we655 tv and replaced the lamp. it still does not work green light blinks and then it powers down right away.
Feb 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony rear proj; kdf 55
If there is no picture but sound is audible then replacing the projection lamp will do otherwise, the TV requires to be diagnosed for any other hardware damages.
Aug 27, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony wega kdf-50we655 went off and thier is a buzzing noise
Anything that sounds like electrical crackling will be coming from either the lamp or lamp driver/ballast boards or their interconnections. The lamp should be examined first as this is the most likely cause.
michtech
Feb 11, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Lamp on the kdf-50we655
Hi, very common to do that, nothing to worry about, video-tek
Feb 10, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
LAMP
Replace the lamp. In rare cases, the lamp power supply or lamp ballast may also need replacing. But, replace the lamp first, and use an original Sony lamp not a cheap aftermarket replacement. If this helps, please be sure to rate the fix! Thanks!
Oct 21, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Was watching TV and now Black with White Lines
I call a tech in. It could be quite a few issues.
May 14, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
104 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
