Question about Nokia 7610
Headset not Supported
When I connect the Nokia Headset "HS-3" on my nokia 7610, it just shows enhancement not supported.
However the same headset works on my phone Nokia 9300.
Why is it so?
  • 178 Answers
Nokia HS-3 is a stereo headset.
Your phone does not support stereo.
So Use mono Headsets like HS-5.
Nokia 9300 is a stereo supported phone and hence works with the headset fine.
Posted on Dec 01, 2007
Headset HS-23 dispays as 'enhancement not supported' when plugged into a nokia 6233
try a different one or check the pin of ur phone is it write or wrong
Jul 11, 2009 | Nokia 6233 Cellular Phone
No sound in handset mode but working fine on loudspeaker
YOu know,its all right with ur phone,but the headset may not be supported by the phone,i mean its enhancement cant support the headset model. change it and it might work.
Jun 10, 2009 | Nokia 3120 Cellular Phone
When i connect the datacable of my nokia 7610 to my pc, it doen't show that the external device is detected,but not working
u must insatll NOKIA PC SUITE in ur pc then u can connect ur mobile to pc by usb data cable....
May 29, 2009 | Nokia Consumer Headset
Enhancement not supported??
It is either Software or Hardware - both solutions below... best of luck
SOFTWARE
Just in case this setting got mixed up, go to menu - tools - settings - general - enhancement - and make sure your default is set to "Headset". If it is already set to "Headset" then it may be a hardware issue...
HARDWARE
The Nokia detects a 2.5mm jack when inserted and defaults to the standard headset mode (sound comes out through the headset but uses the phone speaker). There could be 2 causes to this (1) short in the headset jack or (2) debris in the headset jack that is making a connection between the contacts.
I recommend that you use a "can of air" sprayed directly in the jack to clear any debris. If this does not work, plug in the phone/headset jack that came with it and ensure that it detects it.
If that does not work, it is a short and you should return it or, if it is out of warranty, get someone skilled to replace or disable the jack (only do this is you have no other option -- Nokia won't touch it after you open and solder it).
Feb 09, 2009 | Nokia N73 Cellular Phone
Headset compatability
99% this message coming because the headset u are using is not compatible with this phone, try to go to any accessories shop try their two three kinds of headsets i am sure u will be able to get right one
Jan 29, 2008 | Nokia 2610 Cellular Phone
Nokia 6630 Headset
ok this appears to be a hardware problem on your handset. Actually the moment you connect a headset on to your phone there is an IC that switches on the headset and disconnects the earpiece and microphone of the set and once you remove the headset it should go back to normal. Unfortunately this doesn't happen on your phone so if you do not know what to do u will have to show it to a technician. the only thing that you possible do if u aren't tech savvy is to clean the system connector terminals connect the headset and then remove it. if this works then u will be lucky
Nov 11, 2007 | Nokia 6630 Cellular Phone
No connection withe nokia HS-36W bluetooth headset
First check your headset pair with other handsets if ok. your headset is ok. then check your hand set connection is ok.The default password of hs-36w is 0000
Jan 28, 2007 | Nokia 6230
Search for audio enhancement
Press and hold the On/Off button until the blue light flashes, then search for your headset. This is to initiate the headset for pairing, otherwise it hides from other phones to prevent unintended pairing.
Jan 05, 2007 | Nokia HS-36W Wireless Headset
Not supported
It seems that the headset doesn't match your phone model. You need to contact your costumer support there might be a program or driver updates for this headset. Otherwise you need to change it to a compatible headset for your phone.
Jan 13, 2006 | Nokia HDS-3 Consumer Headset
Nokia 7610 Logo
296 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
