Home Theater Systems
Problem for Home Theater Systems
Generic problem for all Home Theater Systems
No power to the dvd player
By hopkin on Dec 01, 2007
This is the third system I am about to return.. the first two would not power up... this one did work fine until I unplugged it to set it up on a stand.. now I cannot get the power on.
Same Problem
Apr 20, 2009
-   I just purchased a philips hts3544 and when I plug it up the standby light blinks one time and will not turn on. There is some power getting to the system, because the fan in the back turns on. Not sure what to do. -   Guest
Feb 20, 2009
-   I woke up this morning to return a netflix DVD and the DVD player will not turn on...I unplugged it and replugged still no change. I used the remote still no change. I could see the LED light slightly dim when I hit the power button from the remote...but even pressing the button on the player it just will not turn on. -   keilab79
Jan 21, 2009
-   Mine froze on a green/white pic, and when i unplugged it, i heard the same noise and its dead. -   Guest
Jan 10, 2009
-   same problem, need a replacement can not be fixed from anywhere -   Guest
Dec 17, 2008
-   I turned my system on this morning heard a faint pop, like a fuse blowing, and now it won't turn on. I have it plugged into a surge protector that is powering my tv and dish dvr and they both work fine.-   NotADuc
Solution #1
posted on Dec 01, 2007
Somewhat Helpful)
CremeStout
Rank: Master
Rating: 79%, 32 votes
Not sure but since you did not indicate wether this wall plug you are using is the same one you are plugging into when placeing on a stand.
I would say that if it is not the same one it would appear to be the only variable common.
Have someone check that outlet it might be wired wrong (if you don't have a tester ) ----(you can buy a line tester at home depot ,it plugs in to wall and has lights that display how plug is wired) -- I am thinking either you have no ground or polarity is backwards. If you have a VOM measure Nuetral to Ground it should be less than 5 VAC, higher than this is a problem.
Since most amps use low voltage switches internally any variation to the ground will vary the switching voltage.
If you are using the same outlet then the above still applies since when you unplug the poor ground may be shorting internally as you remove.
I would inspect the outlet you are using.
Was this helpful?
Yes
No
Popular Solutions for Home Theater Systems
Questions and Unsolved Problems for Home Theater Systems
Answer
whats better audiovox 300 watt or rca 250 watt home theater system
Answer
which home theatre system would you recommend that have a blu ray player, I have a samsung tv
Answer
Just purchased a 2002 Lincoln LS and the CD changer will not work, can not get door open to player... (More)
Answer
How do you replace the on/off switch? on a ps3
9 Other Users Have The Same Problem - Continued
Comment by melissaduhon, posted on Oct 26, 2008
I have had this system for almost a week and it was working great...until today. It stopped turning on when I decided to finish hooking it up by connecting the radio antenna. It just stopped working. I have tried to plug it in to other outlets; I have unplugged the ac cord from the unit and plugged it back in; I have tested the outlets to make sure they worked (and they did). Nothing works. I would love to know what the problem is. I did not do anything to damage the unit...I did not even move it.
Comment by n8schultz, posted on Oct 01, 2008
Mine will not turn on either. Friend of mine had it for 2 years now its dead. I cannot even figure out how this thing comes apart. No help on any websites. Is this player just garbage? And its not the outlet, that is the lamest suggested solution I can think of.
Comment by snd7wx, posted on Aug 27, 2008
worked last night fine went to turn it on today no power.
Comment by kash08, posted on Apr 10, 2008
worked one minute was shut off went to turn back on and no power or nothing
Describe your Home Theater Systems problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Home Theater... Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
