Beam Industries Sunbeam 1349705 Air Conditioner
Problem for Beam Industries Sunbeam 1349705 Air Conditioner
Is R407c compatible with R134a
By ccrichards on Aug 16, 2009
My airconditioning unit on my caravan is not getting very cold anymore. The data plate states that it has R407C gas in it. Can I use my R134A top-up kit bought for my car? I know R407c contains a blend of R134a so will a pure top-up be ok?
Best Solution
posted on Aug 16, 2009
Helpful)
garing
Rank: Wiz
Rating: 82%, 358 votes
ok stay at2lbs low side
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks to garing for the quick response! " - ccrichards
Solution #2
Helpful)
lordFord
Rank: Guru
Rating: 86%, 57 votes
no absolutely not! Those kits are also more trouble than they are worth if anything at all is not right in the setup. Its worth going and having it done proper, and its not too pricey as long as you phone around enough.My shop in NB charges $10 per pound and a flat rate for labor depending on vehicle. You will burn out the AC in about a month on the wrong refrigerant, they have r34 in r407 as straight up r407 is no longer legal as pure.
Was this helpful?
Yes
No
Popular Solutions for Beam Industries Sunbeam
Questions and Unsolved Problems for Beam Industries Sunbeam
Do you recommend Beam Industries Sunbeam 1349705 Air Conditioner?
Answer
Answer
thin wire filament replacrment for ionic breeze air cleaner
Answer
trying to swith to ritetemp digital
Answer
set the time for an all tech thermostat
Answer
"spillage at draft diverter on wall heater. Should have vent checked" See heater... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , HI
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
