Question about Nokia HS-23 Headset
HS-23 Not Being Recognized by Phone
Hello, I've had the Nokia 6133 for about 2 months, nearing the 3rd, and I've been using the Nokia HS-23 Headset with it for music and calls. However recently, more like just today, the headset wouldn't be recognized when connected to the phone. Usually when the headset is connected a small headset icon will pop up and I'll be able to listen to my music or talk on my phone. All my equipment is basically brand new and I've kept it quite nice. I've used the headset with the same phone for 2 months now and I've connected it and disconnected as the instructions directed me to. I'm not sure how to proceed so I'm here to ask for advice. Thank you in advance.
  • iarecool Dec 17, 2007
    All those didn't work I just emailed Nokia and sent it in. They'll exchange me one for free. Thanks for the advice though.
  • Anonymous Sep 24, 2008
    hello ,
    i am having one n70mobile & iam using nokia hs23 earphone (original}
    one day when am hearing songs,some one has called me...
    from that moment onwards..
    it stoped detecting my headset
    is ther any way to repair those headset???
    pls reply
    arunsisanth@gmail.com
  • 178 Answers
Rub the pins of your headset, and your phone with some tissue paper or something like that.
You might use some cleansining agent like alcohol.
Switch off your phone while doing that.
I too encounter such problems.
Posted on Dec 01, 2007
Can you adjust volume using nokia hs23-headset?
At the side of the headset microphone are 3 buttons, the center is called PTT and the other two adjust the volume.
Jan 12, 2010 | Nokia HS-23 Headset
Headset HS-23 dispays as 'enhancement not supported' when plugged into a nokia 6233
try a different one or check the pin of ur phone is it write or wrong
Jul 11, 2009 | Nokia 6233 Cellular Phone
HS-23 problem disconnected
Assuming that the joint which connects the neck strap has been damaged ( see below image )
, I advice you fix the loosed or broken joint back in its proper place permanently by using fevi kwik or some other fast bonding adhesive, but the only problem which will remain is that each time you have to use the headset you will have to wear it through your head andremove it the same way.
Apr 19, 2008 | Nokia HS-23 Headset
Please help me with a diagram for hs-23 plug connections...
http://free-zg.htnet.hr/GoranJurkovic/nokia/
http://cellphones.hackaday.com/2005/08/16/how-to-make-a-nokia-pop-port-to-female-mini-jack-with-volume/
Dec 03, 2007 | Nokia HS-23 Headset
Headset not Supported
Nokia HS-3 is a stereo headset.
Your phone does not support stereo.
So Use mono Headsets like HS-5.
Nokia 9300 is a stereo supported phone and hence works with the headset fine.
Dec 01, 2007 | Nokia 7610
HS-23 Nokia Headset
hey kev.. all i can ask you is ... the following 1) open the ear piece of the non working .. then take a multimeter (keep meter in resistance mode) and check the resitance if its good it will show you.. apx 32 0hm and if its showing you 0 or .1 or below 16 ohms.. 2) after you disconnect the speaker.. the broken one that is... chek the cable connectivity.. or rather continuity.. for this keep the meter in continuity mode the pervious resistance mode.. then take one wire and connect one prob from meter to it.. and take the other prob and connect ti too the pins of the cnnector.. ( here is there are 4 pins dedicated to the ear phone.. 2 for each.. nd they are towards the end sid.. just below the # key.. frm # key the last 4 pins connectors are for audio.. ) check the.. pins on the cord connector not the phone.. i hope you can find what wrong with your... head set now.. and yeah if the speaker is out jsut replace both the ear piece with sony or aiwa earphones.. it wil work best if your cable is gone then all the best buy a new one tc aditya
Aug 04, 2007 | Nokia HS-23 Headset
No connection withe nokia HS-36W bluetooth headset
First check your headset pair with other handsets if ok. your headset is ok. then check your hand set connection is ok.The default password of hs-36w is 0000
Jan 28, 2007 | Nokia 6230
Nokia HS-23 Headset Logo
213 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
