Question about IBM ThinkPad T41 Notebook
Problems When I turn on my computer it goes through a weird setup where it counts the RAM and has an option of either Temporary boot or Setup. After you get past the windows download with a full battery it just suddenly turns off
    Novelist:
  • 188 Answers
It sounds like a failing hard drive:
You can get hard drive testing software here:
http://www.hitachigst.com/hdd/support/download.htm
Get the ISO download on that page. If you need to know how to burn the ISO to CD properly look here:
http://www.petri.co.il/how_to_write_iso_files_to_cd.htm
IF it keeps shutting off even while testing let me know.!
Posted on Dec 31, 2007
SOURCE:
Entering m100 bios
Two different problems stated, answering in order;
1) "entering Neoware m100 BIOS"
That would be HP Neoware m100 Mobile Thin Client, Notebook PC.
Do to the two statements back to back like that, I feel I need to explain a few things.
If not then ignore, and come back in a Comment; and set me straight.
BIOS
Basic Input/Output System.
A small program.
Used to be 64KiloByte in size, (64KB), but believe smaller now; plus it's smaller in size for a laptop anyway. (Believe 4KB)
When you press the Power On button, the plastic Power On button presses against a carbon contact switch.
The Power On switch is a Momentary Contact Switch.
Touches (Contacts) BRIEFLY, then opens back up.
Power is initiated to the motherboard.
The first chipset to receive power is the BIOS chipset.
The Basic Input/Output System program is initialized.
BIOS looks to see what devices are installed, does a Ram Memory count, turns the Processor on; and hands the computer over to the Operating System.
(Windows)
The BIOS program has a BIOS Setup utility. Most of the time just referred to as BIOS Setup.
In the old days was referred to as CMOS Setup.
B) To enter BIOS Setup (utility), watch the bottom of the monitor screen, CLOSELY; after you press the Power On button.
The proper key to press to enter BIOS Setup; will be shown.
This window often goes by F-A-S-T!
Keep your peepers glued to the screen.
Write the key down.
2) Windows does NOT like having the same build of Windows, put over it. Does not like lesser versions being put over it either.
Do to this you have to force it.
Go into BIOS Setup, and in Boot Options; set the first boot device to CDROM.
This way when you put the O/S disk in the optical drive, it forces the computer to boot from the disk.
HOWEVER, things change when trying to put WinXP over Vista, or Win7.
Awaiting reply, please post back in a Comment.
Regards,
joecoolvette
Mar 25, 2013 | Neoware m100 Notebook
IBM ThinkPad
this can be solved...can you boot to safe mode, through F8?
Mar 07, 2008 | IBM ThinkPad T41 Notebook
SATELLITE U205 ....IS ITPOSSIBLE TO BOOT FROM AN EXTERNAL USB DVD DRIVE
Shut your computer down and remove the power cord.
Replace the power cord and press the "Power" button to restart it.
Watch the screen carefully for a message about computer setup.
Most computers use one of the function keys, which are aligned across the top of the keyboard, to access the computer's setup utility, but each manufacturer uses a different key.
For instance, HP computers generally use the F1 or F10 keys, while many Dell computers use the F12 key.
Press the appropriate function key to enter the computer's setup program, then scroll through the list of options until you see "Boot Order."
The exact location of the boot order option varies from manufacturer to manufacturer, but it is often located under the Advanced menu.
Highlight the "USB Devices" option and press the up arrow key until that device is first on the boot order list.
This will force the computer to look at the external DVD drive first when it boots up.
Use the "Esc" key to exit the setup menu. Choose the "Save settings and exit" option and allow the computer to reboot.
It will now boot from the external DVD drive.
Hope this helps
Sep 26, 2012 | Toshiba Satellite U205-s5057 12" 1.66 Ghz...
I have a dell espirion desktop. When I turn it on it prompts me to start it in safe mode and two other options. Tried each option and nothing happens. Screen goes blank. Nothing. Days ago, computer was...
Try using the Windows operating system reinstall cd and perform a repair installation.
Boot up the computer using the operating system reinstall cd, press F12 and select the cd/dvd drive
When setup loads, and you go to install windows, you can press R to repair the current installation
Dec 20, 2010 | Computers & Internet
How to run 1 gb ram full
usually 1 gb ram runs completely........but in case if you have shared ram with the graphic card......then the ram decreases......! it wil be ok if leave it that way..... otherwise, u can do it by going into the setup of your computer in the start (boot Setup)....then decrease the video card option to its default.
Dec 16, 2009 | Audio Players & Recorders
Dell Inspiron 1420 will no longer boot
you need to enter setup by tapping one of the f keys or the delete key. i'm not sure which it is for this model. when you enter the bios setup change the boot order to boot to the dvd first. hit f10 and save the change then reboot with your install disk in the drive. it should start installing.
Sep 06, 2009 | Dell Inspiron 1420 Notebook
Lap to stops on Bios screen
Reseat your RAM modules, remove and insert them a few times so they make proper electrical contact in the slots.
Jan 15, 2009 | IBM ThinkPad T21 Notebook
Stopping at the BIOS Splash screen
Hi
Reseat all the RAM, CMOS battery and any PCI graphics cards and then try to boot the computer.
Also remove all the memory cards and then turn on the computer. If you dont get any beep sounds, then it is a problem with 1 or more RAM cards.
Then alternatively try with 1 RAM at a time in different slots and check if it is a problem with any of the RAM cards or the RAM slots.
Feb 26, 2008 | IBM ThinkPad T30 2366 Notebook
Start up problems
Looks like you need to reinstall windows. get a windos setup disk and reinstall it. If it does not install cause windows setup cannot detect your c drive, then you may need to change the hd as well
first try reinstalling windows
Feb 17, 2008 | Dell Latitude D600 Notebook
IBM ThinkPad
well actually your battery of your laptop has been dead and it is your software error in the window which shows your battery level full...
if not then try installing new windows....
if this does not work then reply me...
i will tell you other mothods to corrct this error...
reply me soon...
Dec 01, 2007 | IBM ThinkPad T41 Notebook
IBM ThinkPad T41 Notebook Logo
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
