Question about IBM ThinkPad T41 Notebook
IBM ThinkPad When I turn on my computer it goes through a weird setup where it counts the RAM and has an option of either Temporary boot or Setup. After you get past the windows download with a full battery it just suddenly turns off
    Scholar:
  • 181 Answers
Let's try this one thing at a time.
The weird setup counting ram is a setting in the bios which can be disabled. It's the difference between fast boot or not.
As far as the temporary boot or setup goes, is the system already loaded or are you attempting to load now? Sounds as if it indeed needs to be reloaded.
The battery could be anything from the power management utility, to a bad battery, incompatible ac adapter for that model (not likely), or the power bar is not correctly sending power to the battery.
Bottom line, install a fresh copy of the operating system using the ac adapter. If necessary, take the battery out completely.
Good luck, let me know.
Posted on Dec 03, 2007
    Problem Solver:
  • 7 Answers
Well actually your battery of your laptop has been dead and it is your software error in the window which shows your battery level full...
if not then try installing new windows....
if this does not work then reply me...
i will tell you other mothods to corrct this error...
reply me soon...
Posted on Dec 02, 2007
2 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: IBM ThinkPad
this can be solved...can you boot to safe mode, through F8?
Posted on Mar 07, 2008
I have a ibm thinkpad r51 but when i turn it on it will load to somewords and il say media test failure check cable exiting intel boot agent then it will jut stay there
It's trying to boot from a LAN or Network. You want it to boot from your hard drive.
Temporary Fix that you will have to change each time you turn on the laptop:
Notice the screen when you press the power button, at some point it will tell you the keys to hit to get into the Bios or System Setup and the key to hit to Change the Boot Order. Hit the key to Change the Boot Order and select the Hard Drive
Permanent Fix
Notice the screen when it boots up and press the key that allows you to get into the BIOS or System Setup. Tab over to the area that allows you to set the Boot Sequence. Set your Hard Drive as the 1st Boot.
The best boot sequence is:
1. CD/DvD Drive First (Just make sure nothing is in the drive when you boot)
2. Hard Drive 2nd
Apr 21, 2012 | IBM ThinkPad R51 Notebook
IBM ThinkPad
Mar 07, 2008 | IBM ThinkPad T41 Notebook
I want setup windows xp my ibm thinkpad t23 i can pot cd & restart press f12 but not start setup plz halp me haw can i setup windows xp my ibm thinkpad t23
If your trying to reinstall a new copy of Windows in your computer then first thing you need to do is change the Boot sequence of your computer so it will load the Windows CD you inserted then it will run the set up.
To change Boot sequence:
1. Go to BIOS - Press F1 or F2 (depends on model of your computer) immediately after you turn you computer on
2. Go to Boot Menu on the top of the window
3. Change your Boot priority - make sure your dvd drive is your first or primary boot.
4. Press F10 to save and exit.
Make sure you have your Windows CD inserted before pressing F10 coz your computer will restart and will loadautomatically load and run the Windows Setup
Note: If a message "Press any key to boot from CD" appear on a black screen press any key to start the set up
Your Feedback is greatly appreacited.
Hope this information will be helpful. Thank you for using FIXYA.
Apr 21, 2011 | Computers & Internet
When i powerd my thinkpad a31 2652 it prompts me with a passwword i think is a bios code
Actually its not a bios code. Its a password that was been setup during the accessing of its bios. There are two options in setting up such a thing. 1 is for the security of cannot accessing the bios and 2 for not accessing the computer when booting up. Well in your case it was setup in not accessing the computer when booting up. If you set this options definitely you know the password of it. Just type it in the password that you have setup. Then press enter.
Jul 19, 2010 | IBM ThinkPad A31 Notebook
Thinkpad t20 dvd error
Unfortunately only few people know your problems solution but I'm happy that i can help you.
Its simply a problem of setting HDD ( Hard Disk Drive ) type which can be changed using BIOS setup. I hope your laptop must have SATA but if its not working on current settings then please change it to another options available.
Surely, your system will get booted after that and furthermore you can re-install your windows again...
Rate this solution if it was helpful to you.
With Regards,
Shyny
May 29, 2009 | IBM ThinkPad T20 2647 Notebook
Lap to stops on Bios screen
Reseat your RAM modules, remove and insert them a few times so they make proper electrical contact in the slots.
Jan 15, 2009 | IBM ThinkPad T21 Notebook
Ibm thinkpad T22 keyboard defaults
Go through the setup menu and set the numlock option to off. You will need to hit F1if I remember correctly to get to the setup.
Dan
Mar 20, 2008 | IBM ThinkPad T22 2647 Notebook
Stopping at the BIOS Splash screen
Hi
Reseat all the RAM, CMOS battery and any PCI graphics cards and then try to boot the computer.
Also remove all the memory cards and then turn on the computer. If you dont get any beep sounds, then it is a problem with 1 or more RAM cards.
Then alternatively try with 1 RAM at a time in different slots and check if it is a problem with any of the RAM cards or the RAM slots.
Feb 26, 2008 | IBM ThinkPad T30 2366 Notebook
Problems
It sounds like a failing hard drive:
You can get hard drive testing software here:
http://www.hitachigst.com/hdd/support/download.htm
Get the ISO download on that page. If you need to know how to burn the ISO to CD properly look here:
http://www.petri.co.il/how_to_write_iso_files_to_cd.htm
IF it keeps shutting off even while testing let me know.!
Dec 01, 2007 | IBM ThinkPad T41 Notebook
My notebook wont start up
Have you ever been able toboot this machine? Sounds like you have a corporate machine which is configured to boot with several options. If that's the case, you should re-load windows. Get back to me if that's the case. Thanks, harvester3
Aug 18, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T41 Notebook Logo
74 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
