the ignitor keeps clicking no matter what even when it is off. i have to unplug it from the electric outlet to stop the sound. It happened before and i unplugged it for few hours and then it was fine. Now its been a problem for over a week. Any help is greatly appreciated. thank you
Andy
one of the ignitor switches is shorted out.sometimes it is moisture inside and it happens after boilover or spraying some liquid for cleaning.remove the knobs and try a hair dryer to dry them or leave the unit unplugged for some days.it should work fine after this ,if not then the bad switch needs to be replaced.always avoid boilovers and spraying any cleaning liquid for cleaning.
Was this helpful?
Yes
No
Popular Solutions for GE 30 in. Profile JGP989 Gas
My GE Profile Cooktop as a clicking swound when not in use (the clicking sound stops when I pull out...
(More)
My GE Profile Cooktop as a clicking swound when not in use (the clicking sound stops when I pull out thr electric plug from the wall. The clicking is when you turn on a burner to cook something. Can you help me Peter
We use LP gas. The two left hand burners have so much gas pressure that 1/4 to 1/2 of the flames go...
(More)
We use LP gas. The two left hand burners have so much gas pressure that 1/4 to 1/2 of the flames go out. The right hand burners are fine. I can adjust the individual low flame but do not know how to adjust the individual high flame. Any help would be much appreciated.
how do I remove the burner base to clean the gas orfice? The flame on the large burner will not...
(More)
how do I remove the burner base to clean the gas orfice? The flame on the large burner will not adjust to high flame. i believe ther is dirt clogging the orfice.
On a GE jpg989 four burner gas cooktop one igniter has failed. I can se it is not sparking on...
(More)
On a GE jpg989 four burner gas cooktop one igniter has failed. I can se it is not sparking on ignition. Have located the part but not sure if this is an easy or difficult job. How would the igniter be changed??
