the screen remains dark and only 'comes alive' for a second every four seconds or so. I saw a proposed solution from ''GFBusiness'' in which he claims it's fixable, but he left no detailed instructions or list of parts etc., and I could not find his email to contact him.
Basically, I need the part#/description , if possible, a picture of the piece/position to be soldered in. etc.
The problem you have is caused by one of two things,
either a blown power supply in the backlight inverter or bad backlight
bulbs. More than likely it is the bad power supply. The problem in the
power supply are parts called capacitors, they blow out because of the
heat trapped inside the monitor enclosure. If you can solder you should
be able to repair this type of problem. You can go to our web site at: www.ccl-la.com/badcaps.htm
we have pictures of what the capacitors look like when they blow out.
Take the case off the back of your monitor and look for any that look
like the pictures. Replace all of the ones that are bad, the values of
the caps are printed on the side of each one. You can order replacement
caps from several places on the internet or contact us and we can
supply them for you. When installing the replacement caps be sure to
insert the new ones with the stripe on the side going the same way. If
you don't want to do the repairs yourself we offer a repair service. If
you have any additional questions just email me and if you can open the unit and take a few pictures of the boards it would help us guide you.
my moniter blacken out in normal computer mode work on Safe mode only change the monitor to another...
(More)
my moniter blacken out in normal computer mode work on Safe mode only change the monitor to another and it works error mesage on screen signal out of range!!!! what can be th efault?
I had to restart my computer many times to get my monitor worked. But the LED on my monitor did not...
(More)
I had to restart my computer many times to get my monitor worked. But the LED on my monitor did not light and the screen was distorted to the left. I can't fix the monitor by using buttons on it.
My emachine monitor when plugged up will not show anything. The screen is just blank like there is...
(More)
My emachine monitor when plugged up will not show anything. The screen is just blank like there is no power going to it at all. What could be wrong? How do I check it?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
